Then I lost spark sounds like another 914 story as the ignition switch in the early 944 is a very similar part,all is good after replacement and have spark and injector pulse,progress I think but engine is cranking slow,sometimes firing but @ what appears to be out of order
End of story have really bad cold compression in 2 cylinders and a nasty ticking Noise on turnover with plugs out and quess what bent valves,not impressed.
Being a 2.7 it has a one year only head on a 3.0 block so the valves are NASA prices because the inlets are huge (48mm).
Wasn't pleased so pulled the cover of the 914 and started it ,made me feel good for a while,so next question an otherwise nice 944 is worth little now....I suspect little ?
I may drink tonight
