Rear window defogger and no relay board, And what does the main harness fuel pump wire do? |
Mark Henry |
Aug 17 2017, 11:46 AM
For my /6 conversion with relay board delete.
Does the factory rear window defogger have a relay? Or is it just a plug in with a fuse on the board? Also what size is the fuse? If it's just a fuse I'll jump it with an in-line fuse. I know it was working. Thanks (IMG:style_emoticons/default/beerchug.gif) |
IronHillRestorations |
Aug 17 2017, 12:53 PM
I. I. R. C. Group: Members Posts: 6,719 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I think per his original post the relay board was deleted.
Mark, there's a 944 rubber boot that fits over the Bosch square mini relays, I'll see if I can find the PN |
Mark Henry |
Aug 17 2017, 04:42 PM
I think per his original post the relay board was deleted. Mark, there's a 944 rubber boot that fits over the Bosch square mini relays, I'll see if I can find the PN Yep, 1974 914-6 conversion with webers, MSD, no relay board. Eventually I"ll have to add a relay to keep the defog, but it's low on the priority list. Next question, the Black/red wire for the fuel pump, I know that would have triggered a relay, but when I check it (key on) there's no power (or ground) to trigger a relay. (IMG:style_emoticons/default/confused24.gif) I know I can just take power from the switched power. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 01:34 PM |
