Opinions re mid-rise BendPak scissor lift, Flush install |
Cairo94507 |
Aug 17 2017, 02:05 PM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
So I have put my garage off long enough. I was going to add a 4th stall....but I made the mistake of mentioning that to my wife. You can imagine how that went. (IMG:style_emoticons/default/KMA.gif)
I have been married 30 years last May (IMG:style_emoticons/default/screwy.gif) and one would think I would learn my lesson. Just stupid I guess. So, after that abuse, (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/slap.gif) I said, "Hey, I know, I will just remodel the 3 car garage! She signed off on that. Part of the remodel is going to be to add an in-ground, flush installed mid-rise scissor lift into the middle bay of the garage. I have tentatively selected the BendPak MDS-6KF http://www.bendpak.com/car-lifts/specialty...ts/mds-6kf.aspx which has 6K lbs. capacity with a max. lift height of 45.5" and features an "...open-center design that not only allows full unobstructed access to the underside of the car, but is also clear of frame cross member on the floor that are typical with other mid-rise lifts." The cost is $2,310 plus tax and likely a $135 delivery charge for a total of $2,612.48. I like BendPak because the last lift I had, a nice 4 post, was BendPak and it worked beautifully and appeared well made. I see they now offer their lots in Gray- likely what I will get, assuming I am not persuaded to another buy another lift by our esteemed members, as their blue is a bit bright (IMG:style_emoticons/default/shades.gif) for me. Of course I have to saw cut my garage floor and pour some concrete to make a vault for the lift and then I will porcelain tile the whole floor so the lift is absolutely flush with the porcelain tile when done. I will also make a nice table top for the lift so I can have an additional work bench. So, please let me know your thoughts, good or bad, regarding my plan. After all, I can't have my Six coming home to a garage in disrepair. (IMG:style_emoticons/default/beerchug.gif) |
GeorgeRud |
Aug 17 2017, 04:05 PM
Pay attention to the position of your garage door opener as it can also interfere with the lifted car. You might want to experiment with your positioning before cutting the concrete. Ramps are cheap and easy to make.
mepstein |
Aug 17 2017, 05:15 PM
914-6 GT in waiting Group: Members Posts: 19,271 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Pay attention to the position of your garage door opener as it can also interfere with the lifted car. You might want to experiment with your positioning before cutting the concrete. Ramps are cheap and easy to make. (IMG:style_emoticons/default/agree.gif) use it for a while and find the right position. |
Lo-Fi Version | Time is now: 16th May 2024 - 03:40 AM |
