Opinions re mid-rise BendPak scissor lift, Flush install |
Cairo94507 |
Aug 17 2017, 02:05 PM
Michael Group: Members Posts: 9,758 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
So I have put my garage off long enough. I was going to add a 4th stall....but I made the mistake of mentioning that to my wife. You can imagine how that went. (IMG:style_emoticons/default/KMA.gif)
I have been married 30 years last May (IMG:style_emoticons/default/screwy.gif) and one would think I would learn my lesson. Just stupid I guess. So, after that abuse, (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/slap.gif) I said, "Hey, I know, I will just remodel the 3 car garage! She signed off on that. Part of the remodel is going to be to add an in-ground, flush installed mid-rise scissor lift into the middle bay of the garage. I have tentatively selected the BendPak MDS-6KF http://www.bendpak.com/car-lifts/specialty...ts/mds-6kf.aspx which has 6K lbs. capacity with a max. lift height of 45.5" and features an "...open-center design that not only allows full unobstructed access to the underside of the car, but is also clear of frame cross member on the floor that are typical with other mid-rise lifts." The cost is $2,310 plus tax and likely a $135 delivery charge for a total of $2,612.48. I like BendPak because the last lift I had, a nice 4 post, was BendPak and it worked beautifully and appeared well made. I see they now offer their lots in Gray- likely what I will get, assuming I am not persuaded to another buy another lift by our esteemed members, as their blue is a bit bright (IMG:style_emoticons/default/shades.gif) for me. Of course I have to saw cut my garage floor and pour some concrete to make a vault for the lift and then I will porcelain tile the whole floor so the lift is absolutely flush with the porcelain tile when done. I will also make a nice table top for the lift so I can have an additional work bench. So, please let me know your thoughts, good or bad, regarding my plan. After all, I can't have my Six coming home to a garage in disrepair. (IMG:style_emoticons/default/beerchug.gif) |
Cairo94507 |
Aug 17 2017, 05:21 PM
OK- good info. I already have the garage openers resolved. I went with Chamberlain jack shaft openers mounted on the wall right next to the doors. No overhead track or opener over the cars. Cleans up the ceiling and is super quiet.
I have seen Jack Olsen's thread on Garage Journal and that was the thread that convinced me to go with porcelain tile. Since then I have done a ton of reading and if installed correctly, and that is the key, it is as hard as concrete floors. Plus it looks terrific and is easy to keep clean. I will tench the floor for the power and hydraulics and also add another piece of conduit for any future needs for the lift area. I am also considering adding a few, maybe 4, LED lights in the lift bay floor that would illuminate the bottom of the car. Make it easy to see the bottom of the car while you are working under it. Injunmort- If I got a new BendPak and it leaked, they would be fixing it, no doubt about that. Sorry you have had issues with your lift. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:29 PM |
