Removing Porsche Decal, Decal removal |
Mike1981 |
Aug 17 2017, 08:21 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello
Hoping to get some advice on removing an older damaged PORSCHE decal on the bottom of my door and fenders What type of solvent-heat-scraper would you use? Thanks for any advice |
Ed_Turbo |
Aug 17 2017, 10:01 PM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
Use a heat gun and just warm it up. You can get the corner with your fingers and slowly peell it off. Careful when you rub out the adhesive. If you rub it hard enough (even with a terry towel) you can end up with fine scratches. A good way to prevent that is use a rubber razor blade and gently rub it out. Takes time so good luck.
Lo-Fi Version | Time is now: 9th May 2024 - 12:21 PM |
