Removing Porsche Decal, Decal removal |
Mike1981 |
Aug 17 2017, 08:21 PM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello
Hoping to get some advice on removing an older damaged PORSCHE decal on the bottom of my door and fenders What type of solvent-heat-scraper would you use? Thanks for any advice |
burton73 |
Aug 17 2017, 09:44 PM
burton73 Group: Members Posts: 3,515 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
To get it started try a hair dryer not a high temp heat gun. 150 degrees not 212 degrees or more. Never a scraper inn less it is a softer polyethene If you have a paint job you want to keep.
Is the decal clear with white printed on? Getting the residual glue off with the Goof Off is good after you get he film off. Slow going on it. Take you time. Bob B |
Mike1981 |
Aug 18 2017, 08:21 AM
To get it started try a hair dryer not a high temp heat gun. 150 degrees not 212 degrees or more. Never a scraper inn less it is a softer polyethene If you have a paint job you want to keep. Is the decal clear with white printed on? Getting the residual glue off with the Goof Off is good after you get he film off. Slow going on it. Take you time. Bob B Hello Bob Yes it appears to be clear with white Porsche lettering across it It is checked and part of it has peeled off I will apply heat from hair drier and goof off Thanks |
Lo-Fi Version | Time is now: 9th May 2024 - 07:52 AM |
