Boxster calipers. Question for those that have done the swap |
twistedstang |
Aug 18 2017, 05:00 PM
Member Group: Members Posts: 220 Joined: 9-January 06 From: Port Huron, MI Member No.: 5,395 Region Association: None |
So, for those of you that have done the boxster caliper swap and have some miles on your car, how do you like the swap?
Also, have you done the fronts only, or front and rear? What master cylinder are you using? I'm just looking for some real world feedback from the cars that made it off the jackstands. |
Andyrew |
Aug 18 2017, 05:26 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Thats a lot of caliper for a 914. Note that it needs to be balanced front to back or else you'll find yourself just locking up the fronts.
What wheels are you going to be running? What kind of power are you going to be making and how are you going to be driving the car? |
mepstein |
Aug 18 2017, 05:32 PM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
We do it a lot on the 911 builds with 3.2 or 3.6 swaps. Especially if it's going to be tracked. We usually do SC or Carrera calipers on the back.
Steve |
Aug 18 2017, 05:47 PM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I'm running them front and rear courtesy of Rich Johnson. I love them. Awesome braking and quiet. It's been about 5 years now. I don't track it, so I am on the same set of pads. I am running a "T", no proportioning valve. I have autocrossed it a couple of times and slammed on the brakes several times on the street and in an autocross and I have never had the rears lock up first. I am also running a 911 emergency brake, since it's mainly a street car.
Im also running a 19mm master cylinder. Works fine |
tygaboy |
Aug 18 2017, 05:51 PM
914 Guru Group: Members Posts: 5,279 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Tony (Cracker) has them on his car and has said how well they work.
I have them, but won't know how I like them until I get the project on the road. FWIW, I want with Rich Johnson on my set up, too. |
Retroracer |
Aug 18 2017, 06:15 PM
Senior Member Group: Members Posts: 609 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
So, for those of you that have done the boxster caliper swap and have some miles on your car, how do you like the swap? Also, have you done the fronts only, or front and rear? What master cylinder are you using? I'm just looking for some real world feedback from the cars that made it off the jackstands. Liking it so far - but early days for me, only a few hundred miles on the car. I intend to track the car occasionally (track days, not wheel to wheel) once the engine has seen some more road miles. Brake feel is good now the pads are bedded in. Definitely need to address the M/C and rears to get a decent balance. my set up is: front: Boxster calipers, vented disks rear: '88 Carrera ATE calipers + vented disks e-brake: Tangerine racing cable adapters (uses 914 standard cables), '88 Carrera internals M/C: 19mm Prop valve: Wilwood The vented rear disks are probably overkill but the GT's used them - so they look "period correct". I also like the fact you can run 15" rims without clearance issues ;-) Attached thumbnail(s) |
SirAndy |
Aug 18 2017, 06:53 PM
Resident German Group: Admin Posts: 41,610 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I have them front and rear. Best thing i ever did to my brakes.
(IMG:style_emoticons/default/driving.gif) |
burton73 |
Aug 18 2017, 07:13 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
I have fronts and rears bought from Rich Johnston for my V8 car. 911 E brakes set up by Eric at PMB with 930 stub axles.
I am going to be running 2 master cylinders and I have no idea how great they will be as my car is a bit off. Bob B |
Cracker |
Aug 18 2017, 07:40 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
I would say it is a great upgrade no matter how you use your car. I run 997 911 front calipers with base Boxster rear - they work great! My system has two brake masters at 5/8 inch each and a proportioning valve plus a balance bar. Install them and never look back...
Tony |
phillstek |
Aug 19 2017, 02:26 AM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
Would be overkill on a stock powered 4 unless you want the bling.
I went from Alloy S calliper to early boxster on the front. Have SC on the rear and a 19mm MC. Brakes have plenty of feel and never fade no matter how hard I use/abuse them. An excellent upgrade. Attached image(s) |
twistedstang |
Aug 19 2017, 10:58 AM
Thanks for the reply's guys. It just seems there was more negativity towards the swap than positive.
Cracker |
Aug 19 2017, 02:37 PM
Not that it matters to me what calipers you install but are we reading the same thread responses? I didn't see one negative response but plenty of "praises" - who's drinking the kool-aid on this one?
T |
Andyrew |
Aug 19 2017, 05:03 PM
Mine might have been taken as negative. Which is to the contrary, I think they are a great upgrade. My only concern was that if the car is otherwise a stock car going to be driven on the street only then they might be a waste. Also I have doubts they would fit under stock wheels.
mepstein |
Aug 19 2017, 05:18 PM
Mine might have been taken as negative. Which is to the contrary, I think they are a great upgrade. My only concern was that if the car is otherwise a stock car going to be driven on the street only then they might be a waste. Also I have doubts they would fit under stock wheels. I've been told by many people that they fit under stock 15" wheels. I'm not a fan of adaptors but I might try a set on my Suby build. We use the Stompski adaptors on our cars. Stephen stops by the shop once a month to drop off cool stuff. |
Cracker |
Aug 19 2017, 06:34 PM
I have only used the Rebel Racing adapters (I am not a fan of adapters either). I have put mine through the ultimate test and thus far, so good. Just poor communication which is well documented.
T [quote name='mepstein' date='Aug 19 2017, 07:18 P I'm not a fan of adaptors but I might try a set on my Suby build. We use the Stompski adaptors on our cars. Stephen stops by the shop once a month to drop off cool stuff. [/quote] |
timothy_nd28 |
Aug 19 2017, 09:20 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I have a early 911 front end setup with 2.5" M calipers. Does anyone sell a adapter bracket for this?
mgp4591 |
Aug 20 2017, 12:09 AM
914 Guru Group: Members Posts: 5,368 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Test fitting the rears - already have the fronts dialed in. Still using the pressure limiting valve with a 19 mm master. Things should be interesting... Attached image(s) |
phillstek |
Aug 20 2017, 02:56 AM
Not that it matters to me what calipers you install but are we reading the same thread responses? I didn't see one negative response but plenty of "praises" - who's drinking the kool-aid on this one? T Was thinking the same on this but thought oh well best not to go there. Early non S Boxster callipers are the only ones that clear a 15in 911 Fuchs as I recall but could be wrong. |
twistedstang |
Aug 20 2017, 05:47 AM
Not that it matters to me what calipers you install but are we reading the same thread responses? I didn't see one negative response but plenty of "praises" - who's drinking the kool-aid on this one? T Sorry, I was referring to other sources, not this thread. Im gathering parts to do a 5 lug swap and already have a set of boxster front calipers. I'm definitely doing the full swap on my car. I just wanted to hear from guys that have them and like them. This thread reaffirmed it for me. Thanks. Absolutely love your car BTW. |
twistedstang |
Aug 20 2017, 05:55 AM
Not that it matters to me what calipers you install but are we reading the same thread responses? I didn't see one negative response but plenty of "praises" - who's drinking the kool-aid on this one? T Was thinking the same on this but thought oh well best not to go there. Early non S Boxster callipers are the only ones that clear a 15in 911 Fuchs as I recall but could be wrong. Yeah, just went back and reread my last post.... Not what I meant. I read some negative stuff before posting this thread. Mostly from People that haven't ran the brakes. That's why I wanted to hear from those that have. And yes, this thread was full of positive experiences. Thanks again and sorry for my confusing post. |
Lo-Fi Version | Time is now: 2nd May 2024 - 04:04 PM |
