2 Pages V < 1 2
> Boxster calipers. Question for those that have done the swap
Porschef
post Aug 20 2017, 06:07 AM
Post #21
How you doin'
QUOTE(timothy_nd28 @ Aug 19 2017, 11:20 PM) *
I have a early 911 front end setup with 2.5" M calipers. Does anyone sell a adapter bracket for this?
(IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)
Cracker
post Aug 20 2017, 06:16 AM
Post #22
LOL - Got it. Do the upgrade...for the money, it is the best you can do! The Boxster Cup racers are using the same calipers and rotors plus have roughly 500-700 lbs on a full interior 914. I had a G Class PCA racer - phenomenal car (one I should have kept!) and it was mind blowing how good the brakes were (granted, ABS + Power make a world of difference) were. Good luck and reach out to me if you every need any help - I probably won't know the answer but I know who will!
Tony
Cracker
post Aug 20 2017, 06:19 AM
Post #23
Is this a trick question? I could be wrong but they shouldn't need an adapter - they should bolt right up. I ran a set a decade ago (at least by memory)...plug and play.
Tony
post Aug 20 2017, 06:41 AM
Post #24
914-6 GT in waiting
Timmothy - you have 3" struts if they fit M calipers. I thought the adaptors were for 3 1/2" struts. I'll check. If so, I got you covered.
Cracker
post Aug 20 2017, 06:54 AM
Post #25
DUH! Stupid me...that is correct. I was equated his 2.5" mounts to 3" - needed another cup of coffee this morning! (IMG:style_emoticons/default/blink.gif)
T
QUOTE(mepstein @ Aug 20 2017, 08:41 AM) *
craig downs
post Aug 20 2017, 09:58 AM
Post #26
I did a front and rear boxter caliper conversion a few years ago. I used some early 911 struts with 3" spacing. I made my own mounts and had to do some machining on the struts to make them work and the thread is somewhere on here. I love the brakes as they are very powerful. I ran a 19mm master cylinder at first but put on a 23mm later. I tend to like the feel with the 19 better as it takes less effort on the foot but has more pedal travel. My rims are 15" deep 6s with hearts and the fit and I left the stock valve on for the rears.
post Aug 20 2017, 10:54 AM
Post #27
914-6 GT in waiting
QUOTE(craig downs @ Aug 20 2017, 11:58 AM) *
http://www.914world.com/bbs2/index.php?sho...&hl=adaptor
timothy_nd28
post Aug 20 2017, 02:09 PM
Post #28
You are correct Mark, I just measured them and they do read 3"
2 Pages V < 1 2
- Lo-Fi Version Time is now: 10th December 2025 - 01:11 PM
