Clutch advice, Clutch for turbo 914-4 |
Stiffmeister |
Aug 20 2017, 05:20 AM
Newbie Group: Members Posts: 17 Joined: 11-January 15 From: Sweden Member No.: 18,315 Region Association: None |
Hi there. Have a 1971 car. Having a motor from My old karmann ghia (t4). I would like to know what options I have in the clutch departement. The motor should be in the300-350 HP range and the nm that goes with it. Would like a clutch that handles the power but not to be overclutched IF you know what i meen. My own thoughts are like this! Have being looking at a double clutch from KEP but the dolt come in the 215 mm. Can I buy a flywheel for a wasserboxer and buy a 200 mm dubbleclutch and get it to work with My gearbox and starter. Thinking almost normal pedalpreasure but plenty grip and a bit smoothie engagement. Will not be a dragracing car but some trackdays and absolutely streetdriven. Car is probarbly a bit heavier then a original 914-4. Tires are t888 toyos 195-60-15. Please hela me out here and share your thoughts and experanses. Pardon My bad english
McMark |
Aug 20 2017, 06:57 AM
If I read that correctly you're installing the engine into a 914. So you'll need a 914 215mm flywheel, clutch and pressure plate. KEP has the stuff for that HP range and even though you're in Sweden, I would call them. They know their products and can give you the best advice on what to use.
Mark Henry |
Aug 20 2017, 09:54 AM
That HP out of a T4 is quite optimistic and when building remember the 914 is about handling over HP.
That said the 914 transmission will not handle drag race or hard launch starts for very long. First gear is weak and most of the V8 guys who launch hard often end up going with a stronger transmission solution. |
Chris914n6 |
Aug 20 2017, 10:04 AM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I have a Kennedy stage 2 228mm/9" on my swap. Bus size I think. Good for 320 hp or so. Clutchmasters kevlar sport disc.
914 transmission is maxed out around 300hp anyways. |
Stiffmeister |
Aug 20 2017, 12:02 PM
That HP out of a T4 is quite optimistic and when building remember the 914 is about handling over HP. That said the 914 transmission will not handle drag race or hard launch starts for very long. First gear is weak and most of the V8 guys who launch hard often end up going with a stronger transmission solution. Optimistic sure but proven menny times here in sweden over and over. That being said I know off the first gear problem but i dont have to boost IT in first gear. It's being rebuilt with intermediate plate and quaife diff. Perhaps I find the limit (IMG:style_emoticons/default/biggrin.gif) maby I dont. I absolute agree with you..... It's a great handeling car! |
Stiffmeister |
Aug 20 2017, 12:07 PM
I have a Kennedy stage 2 228mm/9" on my swap. Bus size I think. Good for 320 hp or so. Clutchmasters kevlar sport disc. 914 transmission is maxed out around 300hp anyways. How heavy is the pedalpreasure? 228mm. Did you change or modyfy your flywheel? Thank's for your input btw |
Lo-Fi Version | Time is now: 17th May 2024 - 06:30 AM |
