MJLJ mount for a /6, Check it out! |
Dr Evil |
May 18 2005, 01:56 PM
Send me your transmission! Group: Members Posts: 23,000 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
So I was trying to copy the Clewette sensor mount for my MJLJ. I decided that quick steel was the easiest way to get a solid mold for my machinest friend to duplicate. I am thinking now that I may just make a better molded one out of the quick steel and stay with that. You can tap it, drill it, its just like a solid plascic, but harder.
What do you all think? I will attach a pic of Clewette's, and my first attempt. Attached image(s) |
Dr Evil |
May 18 2005, 02:01 PM
Mine is harder to discern, but it fits like a glove.
Dr Evil |
other side
Mueller |
May 18 2005, 02:17 PM
damn that thing is ugly, but with some creative shaping, you can make that thing pretty as well (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
at least I'm not the only one with crazy ideas...I used Playdough to mock up mine (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) It should work, however I'd try to make it so that you can adjust it if needed......... |
Dr Evil |
May 18 2005, 02:19 PM
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) , but I will make the sensor ovular instead of the mount holes. I intend to have studs installed in the mount.
Mueller |
May 18 2005, 02:22 PM
I've never used that material, how well does it mold before it hardens??
got a link?? are you using the wheel I gave you??? |
Dr Evil |
May 18 2005, 02:25 PM
It molds perfectly fine and sets up in 4 min. It is pretty maliable for the first 3 minutes. You can get it at any FLAPS. Get the stuff in the tube. It is a 2 part epoxy with the hardener running through it. You break off the lump amount that you need, kneed it untill it is one color, and then mold it. It is stoopid easy to use and two tubes will due you.
Yup, I am using the wheel that you gave me. It is the perfect diameter. Thanks again. I'll take a pic of the tube and post it. I know that you have seen it before, you may not have noticed it. |
Dr Evil |
May 18 2005, 02:26 PM
Here is a tube. I usually get the tube with out the packaging.
http://www.stock-number.com/quicksteel-met...etal-repair.php Attached image(s) |
Mueller |
May 18 2005, 02:31 PM
cool.....I'll have to buy some to play with it (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif)
you are welcome, at least you are using it, better than it just sitting on my workbench collecting dust (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Dr Evil |
May 18 2005, 03:32 PM
Here it is installed.
Dr Evil |
May 18 2005, 03:33 PM
Front.
Aaron Cox |
May 18 2005, 04:01 PM
mike.....
get that engine in the car man!!!! need it runnin before you move. and you just couldnt have used carbs could ya???? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
DougC |
May 18 2005, 04:10 PM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
What the heck is an MJLJ sensor? I'm installing a six also, is it something I'm overlooking?
Doug C |
Aaron Cox |
May 18 2005, 04:12 PM
mega jolt light juniour or some silly acronym from mega squirt
lapuwali |
May 18 2005, 04:22 PM
Mega Jolt Light Jr. It's a DIY setup for running the Ford EDIS ignition on any car, so you can get distributorless, crank-fire ignition for under $300. It's not really part of the Megasquirt stuff, as it's completely separate hardware, software, everything. The Megasquirt ECU will talk to the EDIS stuff, but it will also talk to GM HEI, and the DIS from the Neon, too. MJLJ only works with EDIS. |
Britain Smith |
May 18 2005, 06:19 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
What are you using for your pulley with the tooth ring? I need to create the same type of mount for my type-4 engine and a 5" pulley. -Britain |
Dr Evil |
May 18 2005, 06:32 PM
Stock /6 pully and a wheel that Mueller gave me.
gaz914 |
May 19 2005, 05:52 AM
Member Group: Members Posts: 67 Joined: 6-March 04 From: Sydney, Australia Member No.: 1,758 Region Association: None |
Keep them progress pics coming.
I want to do the same thing to mine (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) Pics of the "wheel" please. Is there a specific model the sensor and EDIS module came from? We don't have that system here in Aus, so details will help me track one down "over there". cheers GAZ |
3liter914-6 |
May 19 2005, 08:47 PM
Master of Clueless Posts Group: Benefactors Posts: 310 Joined: 12-October 03 From: State College, PA Member No.: 1,238 Region Association: MidAtlantic Region |
Mike, what wheel was that? JY escort pulley? Napa piece? |
Mueller |
May 19 2005, 08:57 PM
NAPA part # CSS304 for the wheel
picture of the wheel (front one is the part above, second one is off an Escort) (IMG:http://www.914world.com/bbs2/uploads/post-2-1094785910.jpg) of course only one wheel and one sensor is used, I was mocking things up (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 03:02 AM |
