Dr Evil
May 18 2005, 01:56 PM
So I was trying to copy the Clewette sensor mount for my MJLJ. I decided that quick steel was the easiest way to get a solid mold for my machinest friend to duplicate. I am thinking now that I may just make a better molded one out of the quick steel and stay with that. You can tap it, drill it, its just like a solid plascic, but harder.
What do you all think? I will attach a pic of Clewette's, and my first attempt.
Dr Evil
May 18 2005, 02:01 PM
Mine is harder to discern, but it fits like a glove.
Dr Evil
other side
Mueller
May 18 2005, 02:17 PM
damn that thing is ugly, but with some creative shaping, you can make that thing pretty as well
at least I'm not the only one with crazy ideas...I used Playdough to mock up mine
It should work, however I'd try to make it so that you can adjust it if needed.........
Dr Evil
May 18 2005, 02:19 PM
, but I will make the sensor ovular instead of the mount holes. I intend to have studs installed in the mount.
Mueller
May 18 2005, 02:22 PM
I've never used that material, how well does it mold before it hardens??
got a link??
are you using the wheel I gave you???
Dr Evil
May 18 2005, 02:25 PM
It molds perfectly fine and sets up in 4 min. It is pretty maliable for the first 3 minutes. You can get it at any FLAPS. Get the stuff in the tube. It is a 2 part epoxy with the hardener running through it. You break off the lump amount that you need, kneed it untill it is one color, and then mold it. It is stoopid easy to use and two tubes will due you.
Yup, I am using the wheel that you gave me. It is the perfect diameter. Thanks again. I'll take a pic of the tube and post it. I know that you have seen it before, you may not have noticed it.
Dr Evil
May 18 2005, 02:26 PM
Here is a tube. I usually get the tube with out the packaging.
http://www.stock-number.com/quicksteel-met...etal-repair.php
Mueller
May 18 2005, 02:31 PM
cool.....I'll have to buy some to play with it
QUOTE |
Yup, I am using the wheel that you gave me. It is the perfect diameter. Thanks again. I'll take a pic of the tube and post it. I know that you have seen it before, you may not have noticed it. |
you are welcome, at least you are using it, better than it just sitting on my workbench collecting dust
Dr Evil
May 18 2005, 03:32 PM
Here it is installed.
Dr Evil
May 18 2005, 03:33 PM
Front.
Aaron Cox
May 18 2005, 04:01 PM
mike.....
get that engine in the car man!!!! need it runnin before you move.
and you just couldnt have used carbs could ya????
DougC
May 18 2005, 04:10 PM
What the heck is an MJLJ sensor? I'm installing a six also, is it something I'm overlooking?
Doug C
Aaron Cox
May 18 2005, 04:12 PM
mega jolt light juniour or some silly acronym from mega squirt
lapuwali
May 18 2005, 04:22 PM
QUOTE (DougC @ May 18 2005, 02:10 PM) |
Doug C |
Mega Jolt Light Jr. It's a DIY setup for running the Ford EDIS ignition on any car, so you can get distributorless, crank-fire ignition for under $300. It's not really part of the Megasquirt stuff, as it's completely separate hardware, software, everything. The Megasquirt ECU will talk to the EDIS stuff, but it will also talk to GM HEI, and the DIS from the Neon, too. MJLJ only works with EDIS.
Britain Smith
May 18 2005, 06:19 PM
QUOTE (Dr Evil @ May 18 2005, 12:56 PM) |
What do you all think? I will attach a pic of Clewette's, and my first attempt. |
What are you using for your pulley with the tooth ring? I need to create the same type of mount for my type-4 engine and a 5" pulley.
-Britain
Dr Evil
May 18 2005, 06:32 PM
Stock /6 pully and a wheel that Mueller gave me.
gaz914
May 19 2005, 05:52 AM
Keep them progress pics coming.
I want to do the same thing to mine
Pics of the "wheel" please.
Is there a specific model the sensor and EDIS module came from?
We don't have that system here in Aus, so details will help me track one down "over there".
cheers
GAZ
3liter914-6
May 19 2005, 08:47 PM
QUOTE (Dr Evil @ May 18 2005, 07:32 PM) |
Stock /6 pully and a wheel that Mueller gave me. |
Mike, what wheel was that?
JY escort pulley? Napa piece?
Mueller
May 19 2005, 08:57 PM
NAPA part # CSS304 for the wheel
picture of the wheel (front one is the part above, second one is off an Escort)
of course only one wheel and one sensor is used, I was mocking things up
Dr Evil
Jun 8 2005, 12:21 AM
Some updated pictures of Muellers gear on my pully as modified my one914racer (Thomas). One914racer is one hell of a great guy and smart too.
He made it so that the gear could be adjusted 10 degrees
Dr Evil
And he is German so the car will like it
Dr Evil
Jun 8 2005, 12:22 AM
He also made the sensor mount pictured next to the pully. I barely need to modify it
Dr Evil
Glorious!!!
Aaron Cox
Jun 8 2005, 12:23 AM
very cool....thomas rocks indeed
