Powdercoating Fan and Steel pulley Wheel, Balancing and Pulley |
914_teener |
Aug 20 2017, 12:18 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Getting ready to send parts out to the powdercoater.
Finally found a decent fan....thanks Kevin, no broken fins. Question: Would you ever need to separate the steel pulley from the aluminum impeller? I know it needs to be dynamically balanced and it already has a small weight pinched on the rim of the pulley. Is it worth splitting the steel pulley from the aluminum impeller and masking the threads that sandwich them together? |
reharvey |
Aug 20 2017, 02:04 PM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
Getting ready to send parts out to the powdercoater. Finally found a decent fan....thanks Kevin, no broken fins. Question: Would you ever need to separate the steel pulley from the aluminum impeller? I know it needs to be dynamically balanced and it already has a small weight pinched on the rim of the pulley. Is it worth splitting the steel pulley from the aluminum impeller and masking the threads that sandwich them together? The best fan is one that has never been taken apart. You've got a good fan so leave it alone and just install it. Nobody is EVER going to see it! |
Lo-Fi Version | Time is now: 17th May 2024 - 07:23 PM |
