Powdercoating Fan and Steel pulley Wheel, Balancing and Pulley |
914_teener |
Aug 20 2017, 12:18 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Getting ready to send parts out to the powdercoater.
Finally found a decent fan....thanks Kevin, no broken fins. Question: Would you ever need to separate the steel pulley from the aluminum impeller? I know it needs to be dynamically balanced and it already has a small weight pinched on the rim of the pulley. Is it worth splitting the steel pulley from the aluminum impeller and masking the threads that sandwich them together? |
Mark Henry |
Aug 20 2017, 02:11 PM
(IMG:style_emoticons/default/agree.gif) you can't see it.
Degrease and/or blast it clean without taking it apart, mask and paint the steel as best you can. I use Nason two stage black on parts like this. Red paint to do the marks and call it done. Also I don't care for PC on pulleys, as it's doesn't wear off where the belt runs and causes a lot of belt slip. Not a huge issue on a T4, but me no likey on T1 and /6. |
914_teener |
Aug 20 2017, 05:10 PM
(IMG:style_emoticons/default/agree.gif) you can't see it. Degrease and/or blast it clean without taking it apart, mask and paint the steel as best you can. I use Nason two stage black on parts like this. Red paint to do the marks and call it done. Also I don't care for PC on pulleys, as it's doesn't wear off where the belt runs and causes a lot of belt slip. Not a huge issue on a T4, but me no likey on T1 and /6. Thanks Mark(s). Media blast it is. |
Lo-Fi Version | Time is now: 17th May 2024 - 07:22 PM |
