Is this really a 914-6 fog light? |
edrotol |
Aug 21 2017, 07:14 PM
edrotol Group: Members Posts: 190 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States |
Hope I am in the correct forum.
Bought a set of fog lights, there seller claiming it is leftover from his 6 eons ago. is it really??? Body has only 4 rivets and certainly can pass for a 4 fog light with same hardware, etc. Clear lens is immaculately clean but: GE logo in center, numbers 297 on one lens and 160 on the other directly under the logo but close to the rim. The photo enclosed shows a 2 prong filament fused to the back of the lens assembly with red and black wiring which is similar to the 4 lights. Obviously the bulb cannot be replaced and looks like the whole lens have to be replaced if broken. The lens is not secured to the body by spring clips unlike the 4 but instead has a rubber surround that secures itself to the body. Comments? |
edrotol |
Aug 21 2017, 07:15 PM
Hope I am in the correct forum. Bought a set of fog lights, there seller claiming it is leftover from his 6 eons ago. is it really??? Body has only 4 rivets and certainly can pass for a 4 fog light with same hardware, etc. Clear lens is immaculately clean but: GE logo in center, numbers 297 on one lens and 160 on the other directly under the logo but close to the rim. The photo enclosed shows a 2 prong filament fused to the back of the lens assembly with red and black wiring which is similar to the 4 lights. Obviously the bulb cannot be replaced and looks like the whole lens have to be replaced if broken. The lens is not secured to the body by spring clips unlike the 4 but instead has a rubber surround that secures itself to the body. Comments? |
edrotol |
Aug 21 2017, 07:17 PM
PCA7GGR |
Aug 21 2017, 07:18 PM
Member Group: Members Posts: 251 Joined: 3-October 03 From: Dublin, CA Member No.: 1,219 |
Nope. It's a 100wt driving light that I make using a stock fog light holding.
toolguy |
Aug 22 2017, 06:27 AM
Senior Member Group: Members Posts: 1,267 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
the bulb looks looks an aircraft landing light. . I had a set of those and they could cook a hotdog
PCA7GGR |
Aug 22 2017, 07:47 AM
Yeap - small air craft landing light. "Driving" light - not "fog" light.
edrotol |
Aug 22 2017, 05:57 PM
PCA7GGR |
Aug 22 2017, 06:12 PM
Due to the high wattage, I recommend use of a relay.
Lo-Fi Version | Time is now: 6th May 2024 - 08:23 AM |
