Desperate for some Help With Microsquirt, Beyond Frustrated |
Mblizzard |
Aug 25 2017, 04:54 PM
I have been trying to get my conversion done in time for Okteenerfest. I have run up against a brick wall and just cant seem to figure out what i am doing wrong.
If anyone can help me by looking at my tune files or providing insight it will be very much appreciated. I can get th car to idle but nothing beyond that. Any use of the throttle is less than impressive and almost useless. Meaning it bogs down and does not accelerate at all. I have no clue what i am missing. 2056 with new low impeadance injectors. Bosch Wideband O2 sensor. Really need some suggestions. Not sure if i can post the tune files here. But will try. |
edwin |
Aug 29 2017, 07:04 AM
Member Group: Members Posts: 321 Joined: 20-May 09 From: Australia Member No.: 10,384 Region Association: Australia and New Zealand |
I'd have a crack at putting the correct injector flow rate in the software.
Pretty sure you'll find static flow is the value used. Also you don't have a barometric sensor connected so get rid of those values at turn the option off. Also worth Turning off cold start corrections off for your initial tune. I can't see what you're doing for lambda sensor. Wired to the ecu? After that it should be slightly more manageable |
Lo-Fi Version | Time is now: 8th May 2024 - 05:59 PM |
