Desperate for some Help With Microsquirt, Beyond Frustrated |
Mblizzard |
Aug 25 2017, 04:54 PM
I have been trying to get my conversion done in time for Okteenerfest. I have run up against a brick wall and just cant seem to figure out what i am doing wrong.
If anyone can help me by looking at my tune files or providing insight it will be very much appreciated. I can get th car to idle but nothing beyond that. Any use of the throttle is less than impressive and almost useless. Meaning it bogs down and does not accelerate at all. I have no clue what i am missing. 2056 with new low impeadance injectors. Bosch Wideband O2 sensor. Really need some suggestions. Not sure if i can post the tune files here. But will try. |
jd74914 |
Aug 29 2017, 08:43 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
It does sound like a hardware issue since you've checked both wires end-to-end. As an aside, I've never been happy with the robustness of MS hardware (Microsquirt in particular). It doesn't self-protect well and doesn't seen to have the greatest quality-control either.
Does TunerStudio allow you to manually turn on an output? That way you could make absolutely sure the pin is not grounding with a plain multimeter. |
Mblizzard |
Aug 29 2017, 08:52 AM
It does sound like a hardware issue since you've checked both wires end-to-end. As an aside, I've never been happy with the robustness of MS hardware (Microsquirt in particular). It doesn't self-protect well and doesn't seen to have the greatest quality-control either. Does TunerStudio allow you to manually turn on an output? That way you could make absolutely sure the pin is not grounding with a plain multimeter. Limited ability to configure outputs. Maybe someone with more skill than I have in electronics could work it out but. I configured a control for my external oil cooler fan but that is about the limit of my ability. All I know is that the first unit had a defective resistor in the injector triggering circuit. This one seems to have an issue in that same circuit. Seems like a consistent issue in this circuit. Could it be my wiring? Sure but the circuit for the injectors is just so simple that it is hard to mess up 2 wires consisting of power and ground. But I will go pull the log and see what they say. |
Lo-Fi Version | Time is now: 8th May 2024 - 12:39 AM |
