Desperate for some Help With Microsquirt, Beyond Frustrated |
Mblizzard |
Aug 25 2017, 04:54 PM
I have been trying to get my conversion done in time for Okteenerfest. I have run up against a brick wall and just cant seem to figure out what i am doing wrong.
If anyone can help me by looking at my tune files or providing insight it will be very much appreciated. I can get th car to idle but nothing beyond that. Any use of the throttle is less than impressive and almost useless. Meaning it bogs down and does not accelerate at all. I have no clue what i am missing. 2056 with new low impeadance injectors. Bosch Wideband O2 sensor. Really need some suggestions. Not sure if i can post the tune files here. But will try. |
jd74914 |
Aug 29 2017, 09:07 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
If you do into Tools>Injector Test Mode you should be able to force your injectors on continuously (set number of repeats to something high, pulse width to max of 65ms, and off time to 0ms). I'd unplug the connectors at that point and just look at the INJ2 pin. If it doesn't ground and the INJ1 pin does, you definitely have a hardware issue. That should take every other component out of the loop.
Mblizzard |
Aug 29 2017, 09:17 AM
If you do into Tools>Injector Test Mode you should be able to force your injectors on continuously (set number of repeats to something high, pulse width to max of 65ms, and off time to 0ms). I'd unplug the connectors at that point and just look at the INJ2 pin. If it doesn't ground and the INJ1 pin does, you definitely have a hardware issue. That should take every other component out of the loop. That is a good Test idea! Will post the results. |
Lo-Fi Version | Time is now: 8th May 2024 - 08:35 AM |
