Desperate for some Help With Microsquirt, Beyond Frustrated |
Mblizzard |
Aug 25 2017, 04:54 PM
I have been trying to get my conversion done in time for Okteenerfest. I have run up against a brick wall and just cant seem to figure out what i am doing wrong.
If anyone can help me by looking at my tune files or providing insight it will be very much appreciated. I can get th car to idle but nothing beyond that. Any use of the throttle is less than impressive and almost useless. Meaning it bogs down and does not accelerate at all. I have no clue what i am missing. 2056 with new low impeadance injectors. Bosch Wideband O2 sensor. Really need some suggestions. Not sure if i can post the tune files here. But will try. |
McMark |
Sep 1 2017, 08:37 AM
Max flow. The idea is to know what the max those injectors are capable of. Everything in the software calculations is scaling down. So if you put in a lower number (50% duty cycle) then the scaling gets done twice, once by you and once by the software.
Mblizzard |
Sep 1 2017, 08:40 AM
Max flow. The idea is to know what the max those injectors are capable of. Everything in the software calculations is scaling down. So if you put in a lower number (50% duty cycle) then the scaling gets done twice, once by you and once by the software. That seems to make sense but it is not well documented in the setup information I have. It is likely the one of those things that should be apparent but I missed it somehow. |
Lo-Fi Version | Time is now: 8th May 2024 - 12:26 AM |
