Desperate for some Help With Microsquirt, Beyond Frustrated |
Mblizzard |
Aug 25 2017, 04:54 PM
I have been trying to get my conversion done in time for Okteenerfest. I have run up against a brick wall and just cant seem to figure out what i am doing wrong.
If anyone can help me by looking at my tune files or providing insight it will be very much appreciated. I can get th car to idle but nothing beyond that. Any use of the throttle is less than impressive and almost useless. Meaning it bogs down and does not accelerate at all. I have no clue what i am missing. 2056 with new low impeadance injectors. Bosch Wideband O2 sensor. Really need some suggestions. Not sure if i can post the tune files here. But will try. |
Mblizzard |
Sep 3 2017, 05:55 AM
Thanks to some very sound advice and guidance above and beyond my wildest expectations. I got to drive the car! Still have a few bugs to work out but overall proforem very well. I think there is more to fix and tune but i can say that even in this less than perfect state this systems performs better than the stock system.
Got to recheck for vac leaks, get the idle control valve set, and revise the AFR and VE tables to fill in a few gaps. Seems to be wandering just a bit on the AFR at times and i have a few values in the current table that just don't work. Going to try and import a table James provided. Thank you sir! |
jimkelly |
Sep 3 2017, 07:26 AM
congratulations ARE in order (IMG:style_emoticons/default/thumb3d.gif)
Thanks to some very sound advice and guidance above and beyond my wildest expectations. I got to drive the car! Still have a few bugs to work out but overall proforem very well. I think there is more to fix and tune but i can say that even in this less than perfect state this systems performs better than the stock system. Got to recheck for vac leaks, get the idle control valve set, and revise the AFR and VE tables to fill in a few gaps. Seems to be wandering just a bit on the AFR at times and i have a few values in the current table that just don't work. Going to try and import a table James provided. Thank you sir! |
Lo-Fi Version | Time is now: 8th May 2024 - 05:45 PM |
