Desperate for some Help With Microsquirt, Beyond Frustrated |
Mblizzard |
Aug 25 2017, 04:54 PM
I have been trying to get my conversion done in time for Okteenerfest. I have run up against a brick wall and just cant seem to figure out what i am doing wrong.
If anyone can help me by looking at my tune files or providing insight it will be very much appreciated. I can get th car to idle but nothing beyond that. Any use of the throttle is less than impressive and almost useless. Meaning it bogs down and does not accelerate at all. I have no clue what i am missing. 2056 with new low impeadance injectors. Bosch Wideband O2 sensor. Really need some suggestions. Not sure if i can post the tune files here. But will try. |
McMark |
Sep 12 2017, 12:46 PM
Injector timing is fixed. There is a setting for it, but I'm not advanced enough to know how big of an impact it can have. My intuition says that it's not very relevant at low levels of tuning. Much like sequential injection doesn't seem to have a large impact on rough tuned engines.
Mike, is your distributors mechanical advanced locked out? You have two options with the distributor/ignition. 1. Lock the MicroSquirt ignition (top left of your image, change the Fixed Advance setting from Use Table to Fixed Timing). 2. Lock the distributor (glue the weights, or otherwise stop the mechanical advance) and use the MicroSquirt timing table to control advance. If you're distributor isn't locked and your setting are like the image you posted, you have two systems fiddling with timing. The results will be unpredictable. |
Lo-Fi Version | Time is now: 8th May 2024 - 02:53 AM |
