1974 limited edition center console, Three holes |
orclean1 |
Aug 27 2017, 06:55 PM
Newbie Group: Members Posts: 6 Joined: 26-August 17 From: NY Member No.: 21,378 Region Association: North East States |
Looking for a correct photo of the center console for 1974 limited edition. . Mine has three gauges but not in a vertical line . Pattern is of a top one on right side ,middle one is in center the bottom one on right
smg914 |
Aug 27 2017, 10:17 PM
Sahara Beige Steve Group: Members Posts: 1,962 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
Looking for a correct photo of the center console for 1974 limited edition. . Mine has three gauges but not in a vertical line . Pattern is of a top one on right side ,middle one is in center the bottom one on right All that means is that your 914 had/has AC installed. When installed, the dealers back in the day would cut the top of the console off and install a shorter 3 hole gauge panel which allowed room for the AC. Yours received the scattered 3 hole gauge panel version. |
smg914 |
Aug 27 2017, 10:27 PM
Here is a photo of my 73 914 with the dealer installed VPC system. My gauges are in the same location as yours.
If your LE no longer has AC, you'll need to find a used uncut console. Attached image(s) |
smg914 |
Aug 27 2017, 10:38 PM
Stock uncut version
Attached image(s) |
Tom_T |
Aug 28 2017, 11:09 AM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
The 3rd type was the DPD AC console with the 3 gauges still stacked but with anew angled bezel. I don't have a pic of one handy, but you can Google for it if you want to see that type too.
(IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Jonathan Livesay |
Aug 28 2017, 12:12 PM
Senior Member Group: Members Posts: 741 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
The 3rd type was the DPD AC console with the 3 gauges still stacked but with anew angled bezel. I don't have a pic of one handy, but you can Google for it if you want to see that type too. (IMG:style_emoticons/default/beerchug.gif) Tom /////// http://www.914world.com/bbs2/index.php?act...t&id=214310 |
Lo-Fi Version | Time is now: 5th May 2024 - 04:25 PM |
