Dash top |
Dash top |
erwindv |
Aug 28 2017, 05:48 AM
Newbie Group: Members Posts: 46 Joined: 17-June 16 From: Belgium Member No.: 20,119 Region Association: Europe |
Is there a difference between the paddding (914 552 031 12) for early (without side vents) and late models (with side vents) as 914Rubber.com makes a difference on their web site: Dash top while the 914_USA_KATALOG only refers to one OEM nr.: 914 552 031 12 for all models?
mepstein |
Aug 28 2017, 06:31 AM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Yes. Early dash tips are slightly different but 914 rubber's can be modded to work on early.
gms |
Nov 7 2017, 10:21 AM
Advanced Member Group: Members Posts: 2,694 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Mikey914 |
Dec 15 2017, 12:28 AM
The rubber man Group: Members Posts: 12,652 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
You can see the reproduction (late) will not line up with the glove box. However, it will not affect the range of motion of the glove box door.
Attached thumbnail(s) |
sixaddict |
Dec 17 2017, 07:11 PM
Senior Member Group: Members Posts: 800 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Mark :
Contrary to my experience. Late dash on early car means GB door interferes and will not open all the way. Am I confused or misunderstand your comment. TOT |
Mikey914 |
Mar 1 2018, 08:34 PM
Mark : Contrary to my experience. Late dash on early car means GB door interferes and will not open all the way. Am I confused or misunderstand your comment. TOT You are incorrect. If you liik on my website you can see mine (late), installed on the early car. Yes the cut out is not alligned, but as it pivots on a point in the center it is travel limited begore it touches the top. See picture above there is clearly 1/8" of daylight between the two. |
Cracker |
Mar 5 2018, 06:19 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
May I see a broader picture of the entire glove box and dash with door shut? The question I would have is the GB recess any different on the drivers side between early and late? As in, is the GB relief in the dash offset to the left visually...
T |
Lo-Fi Version | Time is now: 5th May 2024 - 02:50 PM |
