no power at high speed, around 50mph.... |
bd1308 |
May 18 2005, 10:45 PM
is this a fuel delivery problem (done everything short of taking the gas tank out and getting it...."boiled?") or is this something like a CHT....it books from 0 to around 40...but...it's almost like the rings are shot, just no compression...i mean i can't even accelerate when going up a interstate hill....maybe it's just time to do all three.......
mk114 |
May 18 2005, 10:57 PM
LOST in NO space (my garage) Group: Members Posts: 330 Joined: 29-March 05 From: Salt Lake Utah Member No.: 3,835 |
Mine did the same thing turned out to be combo fuel regulator and vacumn leak
but run compression check to be sure |
Bleyseng |
May 19 2005, 07:38 AM
and check the vacuum advance cuz that will cause the same (no power) symptom (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif)
bd1308 |
May 19 2005, 08:16 AM
well if i unplug it, i believe it runs better than when its plugged in....cause i did that and it idled like its supposed to....when its plugged in, it idles at like 300RPM....its barely turning over...and the idle screw has ZERO effect on the idle....even if the TPS is unplugged. would the compression go to the hell in like 500 miles? b4 it was great, now this started. i think i might try a regulator cause its random enough to be the fix, yet easier than getting compression stuff done
Bleyseng |
May 19 2005, 08:33 AM
I would check your timing and set it at 27 degress BTDC @3500 rpms with the hoses off and plugged. Then set your idle rpms.
Low idle like 300 rpms would indicate the timing is off to me for starters. |
bd1308 |
May 19 2005, 08:34 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) i thought it was 27@3000???? *sigh* back to the start.....
redshift |
May 19 2005, 08:42 AM
Try using the lower speed power more effectively.
(IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) M |
michel richard |
May 19 2005, 08:47 AM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
It would be help ohter readers if you gave info on your setup. which engine ? which fuel system etc ?
I suppose that if no info is given it makes sense to assume "stock everything", but a lot of people in the club have modified their cars. Hope you resolve your problem. Michel Richard |
bd1308 |
May 19 2005, 08:50 AM
2.0 D-Jet stock, pertronix point setup, bosch blue coil, 1974 2.0.......
tat2dphreak |
where are you that 50mph is "high speed" ? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
bd1308 |
May 19 2005, 08:52 AM
it feels like its lean when goign fast.....i'm going to try a regulator off of the 1.7.....it's my gut feeling.
bd1308 |
May 19 2005, 08:54 AM
hey i'm a jeep guy....50mph to a jeep is like real fast.....i've been 75 in my jeep but i thought i was going to die. |
tat2dphreak |
May 19 2005, 08:56 AM
(IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) do 100 in a bettle, then we'll talk about feeling like you're going to die! (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) and we only had lap belts! (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif) |
ChrisFoley |
May 19 2005, 09:01 AM
I am Tangerine Racing Group: Members Posts: 7,923 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Gut feelings are usually incorrect with regard to D-Jet. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
bd1308 |
WTF is a bettle? never ridden in a beetle....i want to do that b4 i die. |
Toast |
May 19 2005, 09:24 AM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
if he was in California, 50 mph would be astounishing speed! (IMG:http://www.914world.com/bbs2/html/emoticons/rolleyes.gif) |
Dr. Roger |
May 19 2005, 09:40 AM
That's great. I did 100mph in my lowered '63 karma ghia convertible w/built up 1600 engine and no factory supplied seat belts. I was young and dumb.... and lived to tell about it. |
michel richard |
Adjusting the fuel pressure would make a difference accross the range of power settings and rpm situations. You may want to rule out ignition stuff before looking at the injection. Are your plugs clean ? nice fat spark ? vaccuum advance working properly etc . . .
Just my .02 Michel Richard |
bd1308 |
May 19 2005, 09:49 AM
i'll check them tonight. it's just one thing after another...... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
JWest |
May 19 2005, 09:56 AM
Did you change something before this occured? What was the last thing you touched before the problem started?
Lo-Fi Version | Time is now: 8th May 2024 - 10:16 AM |
