bd1308
May 18 2005, 10:45 PM
is this a fuel delivery problem (done everything short of taking the gas tank out and getting it...."boiled?") or is this something like a CHT....it books from 0 to around 40...but...it's almost like the rings are shot, just no compression...i mean i can't even accelerate when going up a interstate hill....maybe it's just time to do all three.......
mk114
May 18 2005, 10:57 PM
Mine did the same thing turned out to be combo fuel regulator and vacumn leak
but run compression check to be sure
Bleyseng
May 19 2005, 07:38 AM
and check the vacuum advance cuz that will cause the same (no power) symptom
bd1308
May 19 2005, 08:16 AM
well if i unplug it, i believe it runs better than when its plugged in....cause i did that and it idled like its supposed to....when its plugged in, it idles at like 300RPM....its barely turning over...and the idle screw has ZERO effect on the idle....even if the TPS is unplugged. would the compression go to the hell in like 500 miles? b4 it was great, now this started. i think i might try a regulator cause its random enough to be the fix, yet easier than getting compression stuff done
Bleyseng
May 19 2005, 08:33 AM
I would check your timing and set it at 27 degress BTDC @3500 rpms with the hoses off and plugged. Then set your idle rpms.
Low idle like 300 rpms would indicate the timing is off to me for starters.
bd1308
May 19 2005, 08:34 AM
i thought it was 27@3000???? *sigh* back to the start.....
redshift
May 19 2005, 08:42 AM
Try using the lower speed power more effectively.
M
michel richard
May 19 2005, 08:47 AM
It would be help ohter readers if you gave info on your setup. which engine ? which fuel system etc ?
I suppose that if no info is given it makes sense to assume "stock everything", but a lot of people in the club have modified their cars.
Hope you resolve your problem.
Michel Richard
bd1308
May 19 2005, 08:50 AM
2.0 D-Jet stock, pertronix point setup, bosch blue coil, 1974 2.0.......
tat2dphreak
where are you that 50mph is "high speed" ?
bd1308
May 19 2005, 08:52 AM
it feels like its lean when goign fast.....i'm going to try a regulator off of the 1.7.....it's my gut feeling.
bd1308
May 19 2005, 08:54 AM
QUOTE (tat2dphreak @ May 19 2005, 08:50 AM) |
where are you that 50mph is "high speed" ? |
hey i'm a jeep guy....50mph to a jeep is like real fast.....i've been 75 in my jeep but i thought i was going to die.
tat2dphreak
May 19 2005, 08:56 AM
QUOTE (bd1308 @ May 19 2005, 09:54 AM) |
QUOTE (tat2dphreak @ May 19 2005, 08:50 AM) | where are you that 50mph is "high speed" ? :lol: |
hey i'm a jeep guy....50mph to a jeep is like real fast.....i've been 75 in my jeep but i thought i was going to die. |
do 100 in a bettle, then we'll talk about feeling like you're going to die! and we only had lap belts!
ChrisFoley
May 19 2005, 09:01 AM
QUOTE (bd1308 @ May 19 2005, 10:52 AM) |
it's my gut feeling. |
Gut feelings are usually incorrect with regard to D-Jet.
bd1308
QUOTE (tat2dphreak @ May 19 2005, 08:56 AM) |
QUOTE (bd1308 @ May 19 2005, 09:54 AM) | QUOTE (tat2dphreak @ May 19 2005, 08:50 AM) | where are you that 50mph is "high speed" ? :lol: |
do 100 in a bettle, then we'll talk about feeling like you're going to die! and we only had lap belts! |
WTF is a bettle? never ridden in a beetle....i want to do that b4 i die.
Toast
May 19 2005, 09:24 AM
QUOTE (tat2dphreak @ May 19 2005, 07:50 AM) |
if he was in California, 50 mph would be astounishing speed!
Dr. Roger
May 19 2005, 09:40 AM
QUOTE (bd1308 @ May 19 2005, 07:01 AM) |
QUOTE (tat2dphreak @ May 19 2005, 08:56 AM) | QUOTE (bd1308 @ May 19 2005, 09:54 AM) | QUOTE (tat2dphreak @ May 19 2005, 08:50 AM) | where are you that 50mph is "high speed" ? :lol: |
WTF is a bettle? never ridden in a beetle....i want to do that b4 i die. |
That's great. I did 100mph in my lowered '63 karma ghia convertible w/built up 1600 engine and no factory supplied seat belts. I was young and dumb.... and lived to tell about it.
michel richard
Adjusting the fuel pressure would make a difference accross the range of power settings and rpm situations. You may want to rule out ignition stuff before looking at the injection. Are your plugs clean ? nice fat spark ? vaccuum advance working properly etc . . .
Just my .02
Michel Richard
bd1308
May 19 2005, 09:49 AM
i'll check them tonight. it's just one thing after another......
JWest
May 19 2005, 09:56 AM
Did you change something before this occured? What was the last thing you touched before the problem started?
redshift
May 19 2005, 10:25 AM
QUOTE (James Adams @ May 19 2005, 11:56 AM) |
What was the last thing you touched before the problem started? |
DO NOT ANSWER THAT
dwillouby
May 19 2005, 10:53 AM
Maybe you need 4 more cyl.
David
Joe Ricard
May 19 2005, 02:04 PM
When you are finally done screwing around with that Broken Dizzy please ask me to send you mine.
If it runs good vacuum line disconnected and runs like crap 300 rpm with the hoses connected YOU HAVE A BLOWN DIAPHRAM IN THE ADVANCE UNIT.
I and the rest here will be so happy when you break down and put good parts in your car. 120 MPH in my teener last sunday. held it there for about 3 minutes till I caught the next traffic group.
But I don't know what I 'm doing
bd1308
May 19 2005, 03:21 PM
QUOTE (Joe Ricard @ May 19 2005, 02:04 PM) |
When you are finally done screwing around with that Broken Dizzy please ask me to send you mine. If it runs good vacuum line disconnected and runs like crap 300 rpm with the hoses connected YOU HAVE A BLOWN DIAPHRAM IN THE ADVANCE UNIT.
I and the rest here will be so happy when you break down and put good parts in your car. 120 MPH in my teener last sunday. held it there for about 3 minutes till I caught the next traffic group. But I don't know what I 'm doing |
okay joe...you win. how much $$$ for a good dizzy?
bondo
May 19 2005, 03:34 PM
QUOTE (Joe Ricard @ May 19 2005, 01:04 PM) |
I agree, seems like djet related problems usually occur only at idle, or affect all RPMs something this RPM specific is probably ignition related. Do a complete dizzy swap, and make SURE the hoses are in the right spots.
bd1308
May 19 2005, 04:35 PM
the idle isnt the issue though...the issue is the lack of power. I will try a dizzy swap. 1.7 dizzy's arent compatable with 2.0 dizzy's right...due to the difference in circumference of the dizzy body??
bondo
May 19 2005, 04:42 PM
QUOTE (bd1308 @ May 19 2005, 03:35 PM) |
the idle isnt the issue though...the issue is the lack of power. I will try a dizzy swap. 1.7 dizzy's arent compatable with 2.0 dizzy's right...due to the difference in circumference of the dizzy body?? |
I'm pretty sure the diameters are the same. Advance curves may be different, but not by enough to keep it from running. As long as it has the trigger points in the base, it should work, at least enough to see if you have a dizzy problem.
bd1308
May 19 2005, 05:24 PM
yeah, i just thought the rotational diameter would be different, due to the difference in plug firing(time between cylinder fire)....but i guess i was wrong....lemme pop in my 1.7 dizzy then....
bd1308
May 19 2005, 05:56 PM
i'm grasping at straws here.......
Mueller
May 19 2005, 06:00 PM
QUOTE (bd1308 @ May 19 2005, 04:24 PM) |
yeah, i just thought the rotational diameter would be different, due to the difference in plug firing(time between cylinder fire)....but i guess i was wrong....lemme pop in my 1.7 dizzy then.... |
i don't know what the heck you guys smoke back there, but boy, you should be selling it on eBay and making a fortune
if you did any research, you'd notice that the 1.7, 1.8 and 2.0 all share the same cap, rotor and other consumables.....
bd1308
May 19 2005, 06:02 PM
it's the air man.....and the reformulated gas. i'm putting in my 1.7 dizzy then.
bondo
May 19 2005, 06:08 PM
QUOTE (Mueller @ May 19 2005, 05:00 PM) |
QUOTE (bd1308 @ May 19 2005, 04:24 PM) | yeah, i just thought the rotational diameter would be different, due to the difference in plug firing(time between cylinder fire)....but i guess i was wrong....lemme pop in my 1.7 dizzy then.... |
if you did any research, you'd notice that the 1.7, 1.8 and 2.0 all share the same cap, rotor and other consumables..... |
I got high just reading that!
Rouser
May 19 2005, 06:13 PM
QUOTE (bd1308 @ May 19 2005, 05:21 PM) |
okay joe...you win. how much $$$ for a good dizzy? |
Woah, wait a minute ... haven't we covered this dizzy issue with a couple hundred posts a dozen threads ago already? And STILL again with the dizzy?
Anybody else getting dizzy?
Rand
May 19 2005, 06:14 PM
Bet a dollar when this gets fixed completely, the points would be reliable again.
Not that you'd want to put them back in...
bd1308
May 19 2005, 06:15 PM
i dunno...everything looks great inside of that distributor.....all oiled and sexy and such, but still all i get is hassle....
Bleyseng
Put the 1.7 dizzy in as they are damn near the same other than minor advance differences (so what).
After you get it in and set the proper timing, check the spark on a extra plug by pulling the #1 plug wire and putting on the extra plug which is grounded to the engine good. Have your helper turn over the engine while you look at the spark. It should be bright and a good clear spark.
Now that its running, check the fuel pressure witha pressure gauge. should be 29lbs.
Take it for a test drive.
BTW if the vacuum advance blows out its not that critical as the dizzy is mostly mechanical advance. The weights do stick and the advance won't work, so the engine has not much power do to the timing being stuck at 5 degrees AFTDC
JWest
May 19 2005, 07:50 PM
QUOTE (redshift @ May 19 2005, 11:25 AM) |
QUOTE (James Adams @ May 19 2005, 11:56 AM) | What was the last thing you touched before the problem started? |
DO NOT ANSWER THAT |
Ok, before you touched Miles , what was the last thing ON THE CAR you changed before you had this problem?
bd1308
May 19 2005, 08:15 PM
he's jealous that i have a better looking goat than he does
nebreitling
May 19 2005, 09:05 PM
you're gasping at straws because -- it seems to me -- you are not troubleshooting ultra-methodically. your car's problems could be any multitude of things. you'll never know until you STOP throwing parts at it and start throwing tools, knowledge, research, and logic at it.
maybe that's just a false impression i've got, though. good luck, bro
bd1308
May 19 2005, 09:10 PM
thanks
JWest
May 20 2005, 08:29 AM
Sorry Miles, I try to keep from taking shots at people I have never met, but since you don't really exist...
redshift
May 20 2005, 03:00 PM
No, that was a fabulous turn around...
M
bd1308
May 20 2005, 03:32 PM
no miles, YOURS was a fabulous turn-around....
should have kept it up too
Joe Ricard
May 20 2005, 06:33 PM
Here's a deal 50 bucks for my Proven (rebuilt) 1.7 Distributor.Cap rotor, FI points, a set of plug wires, I'll put your Petronics in it for you. It has good points in it now. Time it probably have to adjust valves too. Plus pay my gas I'll deliver it AND GET YOUR CAR RUNNING.
Any other trouble shooting goes by the hour. I ain't cheap BTW.
Allan
May 20 2005, 06:39 PM
QUOTE (Joe Ricard @ May 20 2005, 05:33 PM) |
Here's a deal 50 bucks for my Proven (rebuilt) 1.7 Distributor.Cap rotor, FI points, a set of plug wires, I'll put your Petronics in it for you. It has good points in it now. Time it probably have to adjust valves too. Plus pay my gas I'll deliver it AND GET YOUR CAR RUNNING. Any other trouble shooting goes by the hour. I ain't cheap BTW. |
Take him up on the offer... Please?
Aaron Cox
May 20 2005, 06:40 PM
dont be an idiot.
we have a known 914 pro ready to make a house call!!!!!!!!
gee! lets see here. get a car running, or try to fix it yourself...
call the man and pay his gas!!!!!!! and buy him alcohol too
in socal, we do these things for free....JK
scotty914
May 20 2005, 06:49 PM
or britt you can ship me your car with 5 grand in cash and a month later it will return with a suby engine in it
Mueller
May 20 2005, 07:01 PM
how about paying Joe $100 to take a match and a gallon of gas over there and
baptizing the car....it would
help all of us
bd1308
May 21 2005, 04:41 PM
dizzy...finally replaced with another good one. Pertronix is on hold for now....no thanks mueller on the baptising.....it's only a car ya know
thanks for the help most of you......
i need these
and not this
