no power at high speed, around 50mph.... |
redshift |
May 19 2005, 10:25 AM
DO NOT ANSWER THAT |
dwillouby |
May 19 2005, 10:53 AM
Member Group: Members Posts: 392 Joined: 27-December 02 From: Mt Washington, KY Member No.: 29 Region Association: None |
Joe Ricard |
May 19 2005, 02:04 PM
When you are finally done screwing around with that Broken Dizzy please ask me to send you mine.
If it runs good vacuum line disconnected and runs like crap 300 rpm with the hoses connected YOU HAVE A BLOWN DIAPHRAM IN THE ADVANCE UNIT. I and the rest here will be so happy when you break down and put good parts in your car. 120 MPH in my teener last sunday. held it there for about 3 minutes till I caught the next traffic group. (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) But I don't know what I 'm doing (IMG:http://www.914world.com/bbs2/html/emoticons/flipa.gif) |
bd1308 |
May 19 2005, 03:21 PM
okay joe...you win. how much $$$ for a good dizzy? |
bondo |
May 19 2005, 03:34 PM
I agree, seems like djet related problems usually occur only at idle, or affect all RPMs something this RPM specific is probably ignition related. Do a complete dizzy swap, and make SURE the hoses are in the right spots. |
bd1308 |
May 19 2005, 04:35 PM
the idle isnt the issue though...the issue is the lack of power. I will try a dizzy swap. 1.7 dizzy's arent compatable with 2.0 dizzy's right...due to the difference in circumference of the dizzy body??
bondo |
May 19 2005, 04:42 PM
I'm pretty sure the diameters are the same. Advance curves may be different, but not by enough to keep it from running. As long as it has the trigger points in the base, it should work, at least enough to see if you have a dizzy problem. |
bd1308 |
May 19 2005, 05:24 PM
yeah, i just thought the rotational diameter would be different, due to the difference in plug firing(time between cylinder fire)....but i guess i was wrong....lemme pop in my 1.7 dizzy then....
bd1308 |
May 19 2005, 05:56 PM
i'm grasping at straws here.......
Mueller |
May 19 2005, 06:00 PM
i don't know what the heck you guys smoke back there, but boy, you should be selling it on eBay and making a fortune (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) if you did any research, you'd notice that the 1.7, 1.8 and 2.0 all share the same cap, rotor and other consumables..... |
bd1308 |
May 19 2005, 06:02 PM
it's the air man.....and the reformulated gas. i'm putting in my 1.7 dizzy then.
bondo |
May 19 2005, 06:08 PM
I got high just reading that! (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) |
Rouser |
May 19 2005, 06:13 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
Woah, wait a minute ... haven't we covered this dizzy issue with a couple hundred posts a dozen threads ago already? And STILL again with the dizzy? Anybody else getting dizzy? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
Rand |
May 19 2005, 06:14 PM
Bet a dollar when this gets fixed completely, the points would be reliable again. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Not that you'd want to put them back in... |
bd1308 |
May 19 2005, 06:15 PM
i dunno...everything looks great inside of that distributor.....all oiled and sexy and such, but still all i get is hassle....
Bleyseng |
Put the 1.7 dizzy in as they are damn near the same other than minor advance differences (so what).
After you get it in and set the proper timing, check the spark on a extra plug by pulling the #1 plug wire and putting on the extra plug which is grounded to the engine good. Have your helper turn over the engine while you look at the spark. It should be bright and a good clear spark. Now that its running, check the fuel pressure witha pressure gauge. should be 29lbs. Take it for a test drive. BTW if the vacuum advance blows out its not that critical as the dizzy is mostly mechanical advance. The weights do stick and the advance won't work, so the engine has not much power do to the timing being stuck at 5 degrees AFTDC |
JWest |
May 19 2005, 07:50 PM
Ok, before you touched Miles (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) , what was the last thing ON THE CAR you changed before you had this problem? |
bd1308 |
May 19 2005, 08:15 PM
he's jealous that i have a better looking goat than he does
nebreitling |
May 19 2005, 09:05 PM
you're gasping at straws because -- it seems to me -- you are not troubleshooting ultra-methodically. your car's problems could be any multitude of things. you'll never know until you STOP throwing parts at it and start throwing tools, knowledge, research, and logic at it.
maybe that's just a false impression i've got, though. good luck, bro (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
bd1308 |
May 19 2005, 09:10 PM
thanks
Lo-Fi Version | Time is now: 8th May 2024 - 01:23 AM |
