Instrument panel for Neo914, some parts are fitting nicely |
neo914-6 |
May 19 2005, 01:00 AM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Need just a slight mod to make it fit perfect...
Planned for a flat panel display but this should work after I sort out the wiring... Attached image(s) |
914_1.8t |
May 20 2005, 09:36 AM
Member Group: Members Posts: 302 Joined: 3-June 04 From: East Bay Member No.: 2,149 |
Felix, Wasn't too difficult for me. Do you have the internal harness for the S4? If not, I have a spare body haness out of a Audi A4 sitting in my shed that we can probobly use to mate to your setup. Since the internal harness only provides power to the ECU and accesories, we can make it work and will make the job easier. The ECU and engine can run with just the engine harness...you just need to provide power to the ECU (very easy once you look at the wiring diagram, it is only one wire and the wiring diagrams show you what type of fuse to use). ECU has wires coming out of it that give signal to the Dash...speedo, water temp, and RPM are the main ones you need. It's gets even easier (you won't need the internal harness) if you don't want to use the audi relays to contrl water temp (radiator fans) and fuel pump. You can run power to the lighting on the cluster wired into your 914 headlights/interior lights switch. However, since I had the internal harness, I just trimmed it and kept the functionality I wanted. Not sure if the S4 had the "immobalizer" feature...but people have posted workarounds for this over on vwvortex. Let me know when you get to the wiring stage...i'll help out the best that I can. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
Lo-Fi Version | Time is now: 24th May 2024 - 09:58 AM |
