New part anyone want to help me check fit and operation. Cooling tin bushings, I have a few of these I can sell now for $9.14 a set shipped domestic. |
whitetwinturbo |
Sep 4 2017, 12:52 PM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
Had a girlfriend with IUD like that.......... (IMG:style_emoticons/default/grouphug.gif)
Specracer |
Sep 4 2017, 04:57 PM
Member Group: Members Posts: 100 Joined: 27-March 17 From: SE Mass Member No.: 20,970 Region Association: None |
I was cleaning and lubricaling those bushings that the cooling flaps slide into just yesterday. Ironic.
rfinegan |
Sep 11 2017, 05:59 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I installed the cooling flap bushings this week end. The left side I was able to sneak into the tin/housing and slid it into place and then clock into the slot. Snapped right onto the shaft and was ez to install on shaft then the old to get off. The right side(tin off) seemed to sit a little proud of the fan using and I was concerned that it would interfere with the tin once installed. See pic. But once installed I did not have any issue. Smooth as silk operation. No more bind I was experiencing with the old ones. I measured a few dimensions with a caliper for comparison and the pics of the install. NO modifications were needed to install and operation is perfect.
Attached thumbnail(s) |
rfinegan |
Sep 11 2017, 06:02 AM
I installed the cooling flap bushings this week end. The left side I was able to sneak into the tin/housing and slid it into place and then clock into the slot. Snapped right onto the shaft and was ez to install on shaft then the old to get off. The right side(tin off) seemed to sit a little proud of the fan using and I was concerned that it would interfere with the tin once installed. See pic. But once installed I did not have any issue. Smooth as silk operation. No more bind I was experiencing with the old ones. I measured a few dimensions with a caliper for comparison and the pics of the install. NO modifications were needed to install and operation is perfect. Attached thumbnail(s) |
rfinegan |
Sep 11 2017, 06:04 AM
another
Mikey914 |
Sep 13 2017, 10:47 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have a few sets I can sell now, doing a GB on these at $9.14 a set
porbmw |
Sep 13 2017, 01:45 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
markhoward |
Sep 13 2017, 02:03 PM
Member Group: Members Posts: 375 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California |
I'm in for a set (IMG:style_emoticons/default/smile.gif)
Mikey914 |
Sep 13 2017, 02:13 PM
Thanks for the support but the 6 has a slightly different setup.
Attached thumbnail(s) Attached image(s) |
mobymutt |
Sep 13 2017, 02:40 PM
Senior Member Group: Members Posts: 550 Joined: 16-December 13 From: Kingston, Ontario, Canada Member No.: 16,770 Region Association: Canada |
There are supposed to bushings there? No wonder I couldn't get that shaft to turn nicely. I'm in for a set, if you can put it in an envelope and ship to Canada.
nditiz1 |
Sep 13 2017, 06:28 PM
Senior Member Group: Members Posts: 1,188 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I'll take a set for the future.
barefoot |
Oct 3 2017, 10:12 AM
Senior Member Group: Members Posts: 1,275 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
914Sixer |
Oct 3 2017, 12:25 PM
Never got my test set. Put me down for 2 sets.
914_teener |
Oct 3 2017, 09:05 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Got my set last week Mark.
Got my tin back from powder coat so I'll be setting the flaps into the shroud this weekend. I snap so pics as promised. It looks like others have beat me to it. I'll post some pics anyway and thanks for doing these. I'm missing all the the engine tin stuff so I'll be ordering that soon. By next month I should be ready for the long block for the tin to go onto (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/beerchug.gif) Next stop new 2.0 harness from Bowlsby, that will complete all the FI stuff. It's great to have folks that support our habit. |
Mikey914 |
Oct 3 2017, 10:52 PM
914_teener |
Oct 13 2017, 09:22 PM
Finally got around to this. Most of my tin assembly is done but I don't have the long block yet. So gonna move on to other stuff. I'll be highlighting this in my build thread as a "finer point" but just when you are putting this assembly together:
The tang on the shaft goes in the middle slot in the bushing. That is the bushing next to the oil cooler flap. Just thought I'd mention it. Thanks for the parts Mark, they seem fine, no binding. Pic |
maf914 |
Oct 14 2017, 04:20 PM
Mark W,
Help! I can't seem to find these bushings on your web site. How are they listed? Thanks. |
Mikey914 |
Oct 14 2017, 06:35 PM
We are just doing the full production run this week.
How quick do you need a set? Sure I can get listed up this next week no problem have about 10 sets from proto run. |
Kansas 914 |
Oct 14 2017, 07:22 PM
Mikey914 |
Oct 14 2017, 07:51 PM
I'll get an official GB thread going in the next day or so. Actually taking some time to hang with the wife at a horse show.
Lo-Fi Version | Time is now: 18th May 2024 - 04:24 PM |
