Quick-Jack, XL or EXT |
simonjb |
Sep 2 2017, 03:32 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Hi,
Could someone tell me the distance between the jacking donuts - center to center? I am trying to decide between the 5000XL or the 5000EXT. One is 60" and the other is 66" Thanks! |
Wyvern |
Sep 2 2017, 04:40 PM
Member Group: Members Posts: 324 Joined: 7-October 15 From: San Francisco (East Bay) Member No.: 19,245 Region Association: Northern California |
Center to Center is 49"
My concern is that it is SO short that it would be too long when collapsed to just slide under the car. I just measured it as I am trying to find the Quick Jack that will work on both the 914 & Cayman. |
Wyvern |
Sep 2 2017, 04:43 PM
914forme |
Sep 2 2017, 05:27 PM
Get the normal length, it is very easy to extended the platform if you need to lift something bigger. Friend has a Cayman and a Cayenne. Had to make the set of extensions for his 7000XL it fits under the Cayman with out the extension, and then bolt on the extensions and lift the Chilli.
This is my Merc up on it. And here they are all alone Easy enough to do, and it is the best of both worlds. Other things I would like to do if they where mine. Better casters to make it easier to move and not scratch my floor paint. Handles to make them easier to lift into the bed of the truck. |
iankarr |
Sep 2 2017, 06:16 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Center to Center is 49" My concern is that it is SO short that it would be too long when collapsed to just slide under the car. I just measured it as I am trying to find the Quick Jack that will work on both the 914 & Cayman. Just measured my Cayman 987.2 at 55 inches between lift points. I have the older model QJ5000 (which is marginally long enough even for the 914) and am about to pull the trigger on a larger QJ...so we're in the same boat. Check this link and the measuring table at the bottom for more info. I think I'm going with the 7000 SLX so I can also lift my Jeep. 914forme - Those extensions seem like they'd work, but I'd be a little concerned that the higher center of gravity and narrower base would change the safety profile of the lift. Probably fine, but when it comes to getting under a car, I'm super conservative. Be safe! https://www.quickjack.com/quickjack-measuring-guide.html |
Rand |
Sep 2 2017, 10:19 PM
The 914 fits within those specs. She ain't fat.
914forme |
Sep 5 2017, 07:55 PM
Center to Center is 49" My concern is that it is SO short that it would be too long when collapsed to just slide under the car. I just measured it as I am trying to find the Quick Jack that will work on both the 914 & Cayman. Just measured my Cayman 987.2 at 55 inches between lift points. I have the older model QJ5000 (which is marginally long enough even for the 914) and am about to pull the trigger on a larger QJ...so we're in the same boat. Check this link and the measuring table at the bottom for more info. I think I'm going with the 7000 SLX so I can also lift my Jeep. 914forme - Those extensions seem like they'd work, but I'd be a little concerned that the higher center of gravity and narrower base would change the safety profile of the lift. Probably fine, but when it comes to getting under a car, I'm super conservative. Be safe! https://www.quickjack.com/quickjack-measuring-guide.html Stable as can be, I shook the living crap out of it before I put my melon under it. Super stable, with the Benz you have to run the engine to set the transmission fluid level. I wanted to make sure it was stable, hate to drop 5000 lbs of MB Diesel onto the floor of the garage, while my sorry ass was under it. Safety first you know. |
PlaysWithCars |
Sep 6 2017, 12:00 AM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
XL. I believe the EXT is too long to fit between the wheels. XL works perfect on my car.
I'll have to look into fabbing an extension bed. The XL is too short to hit the lift points on our X5. |
Wyvern |
Sep 6 2017, 12:26 AM
Just thinking out loud ... someone could make some $ making the "Extenders"
"914forme" looks like some 1x1 and boxed it . how does it actually mount ? |
IanJ |
Sep 15 2017, 11:01 PM
Member Group: Members Posts: 90 Joined: 28-December 05 From: Perth, Western Australia Member No.: 5,327 Region Association: Australia and New Zealand |
I have a set of the 5000XL and they fit snugly between the wheels. You can also use them across the width of the car if you needed to.
Has anyone come up with creative ways to get more height? The manual states you can stack the rubber blocks but this is very shaky and even then doesn't give me much room for my subaru engine and trolley (I'm working on a lower trolley to help). |
90quattrocoupe |
Sep 16 2017, 12:12 AM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
A friend of mine uses one on his B3 Audi. He puts jack stands under it to steady it even more.
Greg W. |
Lo-Fi Version | Time is now: 5th May 2024 - 07:04 AM |
