QUOTE(cuddyk @ Sep 2 2017, 08:16 PM)
QUOTE(Wyvern @ Sep 2 2017, 06:40 PM)
Center to Center is 49"
My concern is that it is SO short that it would be too long when collapsed to just slide under the car.
I just measured it as I am trying to find the Quick Jack that will work on both the 914 & Cayman.
Just measured my Cayman 987.2 at 55 inches between lift points. I have the older model QJ5000 (which is marginally long enough even for the 914) and am about to pull the trigger on a larger QJ...so we're in the same boat. Check this link and the measuring table at the bottom for more info. I think I'm going with the 7000 SLX so I can also lift my Jeep.
914forme - Those extensions seem like they'd work, but I'd be a little concerned that the higher center of gravity and narrower base would change the safety profile of the lift. Probably fine, but when it comes to getting under a car, I'm super conservative. Be safe!
https://www.quickjack.com/quickjack-measuring-guide.htmlStable as can be, I shook the living crap out of it before I put my melon under it. Super stable, with the Benz you have to run the engine to set the transmission fluid level. I wanted to make sure it was stable, hate to drop 5000 lbs of MB Diesel onto the floor of the garage, while my sorry ass was under it.
Safety first you know.
