A bit of this and that,, good results |
porschetub |
Sep 3 2017, 03:11 PM
Well been a while but got off other jobs to work on the car,pulled the oil tank after start of oil change,oil needed changing as engine was unknown when fitted.
Oil was pretty dirty and smelt slighty of fuel....not great so good timing. Tank out ,I found the hose fitting a little loose but a bit worried about the fitting the PO supplied as the TIG welding was a bit suspect ,fixed that after having a leak there for ever ,real pleased with the outcome. Thought I was clever with my carbs but in real terms still too rich @ idle,black dirty plugs and fuel smoke at idle so changed out the jets for original and found much improved result so I now have a baseline as these are a touch lean. Changed out worn/damaged fan outer pulley and belt so that noise has gone away...another result (IMG:style_emoticons/default/biggrin.gif) ,retimed the engine and checked carb set up. One more oil leak to sort was around the oil thermostat,turned out to be crappy breather hose from Pelican parts,geez fought that one (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . Exhaust valve covers are still not sealed and weeping a bit enough to piss me off,resufaced twice so basically have to think about replacements but really expensive by the time I get alloy ones here,would seem the magnesium ones reach a point of no repair. Well as it transpired a set of latter alloy covers came up on our countries biggest auction site,scored them for 100nzd so another good result. Had a bad VDO day yesterday,my combo gauge is from a 77 911 but the temp gauge insert died, fitted a replacement metric inset I had and that was faulty also (IMG:style_emoticons/default/headbang.gif) ,remote mounted a cheap universal one I had so atleast that worked. |
Sep 3 2017, 03:32 PM
The alloy covers aren't exactly known for good sealing, either. They also put a lot of stress on the rocker studs. I believe some people have gone with step studs to try to help that.
--DD |
porschetub |
Sep 4 2017, 12:26 AM
The alloy covers aren't exactly known for good sealing, either. They also put a lot of stress on the rocker studs. I believe some people have gone with step studs to try to help that. --DD Yes have thought about that,thinking the right gaskets I should be better off,one cover is cracked (air side) and not easily welded. One of the wise gents on Pelican mentioned the alloy ones don't stay flat also (IMG:style_emoticons/default/WTF.gif) . |
Sep 4 2017, 03:59 PM
One of the wise gents on Pelican mentioned the alloy ones don't stay flat also (IMG:style_emoticons/default/WTF.gif) . I wonder if that was me? I'm over on Pelican, and there's one part of me that's pretty wise.... (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/wink.gif) --DD |
porschetub |
Sep 5 2017, 04:52 PM
One of the wise gents on Pelican mentioned the alloy ones don't stay flat also (IMG:style_emoticons/default/WTF.gif) . I wonder if that was me? I'm over on Pelican, and there's one part of me that's pretty wise.... (IMG:style_emoticons/default/bootyshake.gif) (IMG:style_emoticons/default/wink.gif) --DD (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) sorry Dave it wasn't you,recieved the covers in the post ,dirty but in great shape,will run then over my glass surfacing plate to see if they are still flat,can't decide if I should paint them or not (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/confused24.gif) . Problem with the old magnesium ones I had was that some monkey had used very thick gaskets and tightened the crap out of them...think that's way one was cracked. I have found a VDO repair agent down south so plan to send of my faulty gauge temp inserts for repair hopefully they can get atleast one going? |
gms |
Sep 5 2017, 05:21 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
Exhaust valve covers are still not sealed and weeping a bit enough to piss me off,resufaced twice so basically have to think about replacements but really expensive by the time I get alloy ones here,would seem the magnesium ones reach a point of no repair. I bought the billet aluminum covers from Hargett Precision and haven't had a leak in 4 years |
Sep 5 2017, 11:11 PM
porschetub |
Sep 6 2017, 12:02 AM
...recieved the covers in the post ,dirty but in great shape ... Aw, heck! I completely missed the fact that you were talking about 911 valve covers!!! My comments were about the alloy covers for the four-cylinder engines. D'OH! --DD No no ,no mistake really ,have a set of those going on a T4 'Iam slowly building up oh dear,do they pull the rocker stud from the head??? don't know as have never used them before ? (IMG:style_emoticons/default/beer.gif) . |
IronHillRestorations |
Sep 6 2017, 07:22 AM
"Turbo" lower covers won't fit a 6 without grinding some off. You can put them on the engine as is, put your engine in the car, and be unable to get the lower covers off.
I have 5/16" milled off the entire ribbed side. |
porschetub |
Sep 6 2017, 02:00 PM
"Turbo" lower covers won't fit a 6 without grinding some off. You can put them on the engine as is, put your engine in the car, and be unable to get the lower covers off. I have 5/16" milled off the entire ribbed side. Thanks Perry have that covered,have use of a milling machine @ my brothers workshop (IMG:style_emoticons/default/beer.gif) . |
porschetub |
Sep 8 2017, 12:28 AM
Good day today cause it wasn't raining ALL... day (IMG:style_emoticons/default/headbang.gif) .
Got Ford starter relay fitted as Mark Henrys "how to" thread ,easy job to do and cheap as I had the wires and payed $6 for connectors and around $25 delivered for the relay ex Ebay....cant go wrong really. Hardest part was bending the mounting tab to go on to the lower starter bolt,used glued heatshrink ,good and solid on all connections. Next job was to fit my LED headlight lamps for my H4 headlights; Happy with the fit of these but its not possible to fit the rubber sealing boot so made some seals out of closed cell foam that will offer some sort of seal. |
porschetub |
Sep 8 2017, 01:08 AM
porschetub |
Oct 22 2017, 02:16 AM
Well have been busy as on my property,so time for some Porsche love after lawns mowed and tree's trimmed,issues I had were gearshift related,packing out the pivot ball has made a huge difference as I thought,it shifts a hot knife into butter...never thought I could make it this good.
Used the Tangerine racing adjustment procedure after trying every other method (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Carbs are tuned and happy,engine timing needs work as a little advanced,easily sorted. Got the bastard counterfeit Momo steering wheel hub sorted,took lots of work. Nice wheel to drive with and easy on my legs but still pissed on the quality...never mind not worth bitching anymore. |
porschetub |
Nov 1 2017, 03:31 AM
Nov 1 2017, 11:15 AM
You've gotta stop taking photography lessons from Sir Andy.... (IMG:style_emoticons/default/biggrin.gif)
--DD |
porschetub |
Nov 1 2017, 01:04 PM
You've gotta stop taking photography lessons from Sir Andy.... (IMG:style_emoticons/default/biggrin.gif) --DD I know ,has taken years of experience to take pictures this badly (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) . |
porschetub |
Nov 1 2017, 01:25 PM
Then I repainted the wheel to correct colour ,they were previously matt black instead of satin.
Then I thought...fail should have done the petals in matt silver first,anyway after a huge amount of masking I ended up with a reasonable result. Used VHT high temp wheel silver paint which is a good match for the look I was after. |
porschetub |
Nov 2 2017, 04:12 PM
Had a test drive last week and had so many issues I didn't feel like mentioning it,the main issue was the gearshift again which unknown to me had gone out of alignment on the rear rod due to a loose bolt in the rear universal,it shifted fine @ the start of the drive,by the time I headed home it was all screwed up (IMG:style_emoticons/default/headbang.gif) .
Sorted that and decided to address my timing issue,this turned out to be a faulty strobe light or it doesn't like my ignition system ?....haven't narrowed it down yet,retarded the timing and all is good again. Went for a spirited drive last night and she was really "on song",somewhat transformed from last time. Pulled plugs and checked them,great colour so won't be touching the carbs a again (IMG:style_emoticons/default/dry.gif) ,final setup is ; 30mm vents , 52 idles, 125 mains, stock emulsion tubes as per alfa1750's recommendation, mixtures screws out 2.5 turns, air bleeds (some but not all )slightly opened as per manual, idle speed screws open half a turn/carb. Next jobs are to equalize the handbrake, replace RH side rear wheel bearing and fit Boxster wiper motor ,I need to weld up the cutout for the cooler that the OP was going to fit up front ...hopefully then I will be closer to road legal. |
Lo-Fi Version | Time is now: 16th May 2024 - 08:00 AM |
