Well been a while but got off other jobs to work on the car,pulled the oil tank after start of oil change,oil needed changing as engine was unknown when fitted.
Oil was pretty dirty and smelt slighty of fuel....not great so good timing.
Tank out ,I found the hose fitting a little loose but a bit worried about the fitting the PO supplied as the TIG welding was a bit suspect ,fixed that after having a leak there for ever ,real pleased with the outcome.
Thought I was clever with my carbs but in real terms still too rich @ idle,black dirty plugs and fuel smoke at idle so changed out the jets for original and found much improved result so I now have a baseline as these are a touch lean.
Changed out worn/damaged fan outer pulley and belt so that noise has gone away...another result ,retimed the engine and checked carb set up.
One more oil leak to sort was around the oil thermostat,turned out to be crappy breather hose from Pelican parts,geez fought that one .
Exhaust valve covers are still not sealed and weeping a bit enough to piss me off,resufaced twice so basically have to think about replacements but really expensive by the time I get alloy ones here,would seem the magnesium ones reach a point of no repair.
Well as it transpired a set of latter alloy covers came up on our countries biggest auction site,scored them for 100nzd so another good result.
Had a bad VDO day yesterday,my combo gauge is from a 77 911 but the temp gauge insert died, fitted a replacement metric inset I had and that was faulty also ,remote mounted a cheap universal one I had so atleast that worked.
