Has anyone used an interior light from a 911?, It's in. Higher quality light, fits nicely |
arne |
Sep 5 2017, 04:56 PM
Serial Rescuer of old vehicles... Group: Members Posts: 737 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
I got one of the normal aftermarket replacement lights for my car's back pad (no silver rim, black switch), and like others, I'm not impressed.
Then I wondered how much difference in size and mounting is there between the 914 light and one of the dome lights in my 911? Turns out, not much. The 911 light is about the same length, and just a bit wider. I'd still need to enlarge the hole a bit. But it's a more vintage look, especially if you use the early light with the stainless rim. (It also comes with black rim.) I think I'm going to give it a try. Anyone else done this? The light I am looking at is this one. |
arne |
Sep 5 2017, 05:45 PM
Frankvw |
Sep 12 2017, 03:37 AM
working on my first 914 ! Group: Members Posts: 651 Joined: 13-April 16 From: Holland, the Netherlands Member No.: 19,896 Region Association: Europe |
interesting option, and for sure more classic looking than that new-beetle option (which is a nice option in case you do not mind it is not original/classic enough).
Did you already try to install this? |
914Sixer |
Sep 12 2017, 07:05 AM
911 switch is nothing more than a VW Type 3 dome light.
arne |
Sep 12 2017, 08:45 AM
interesting option, and for sure more classic looking than that new-beetle option (which is a nice option in case you do not mind it is not original/classic enough). Did you already try to install this? 911 switch is nothing more than a VW Type 3 dome light. Or maybe it's the other way around, the Type 3 used the Porsche light. The light is also listed for later 356, and carries a Porsche part number (901.632.101.00) rather than a VW number. Dunno, and not terribly important to me either way, if I can make it fit and work. |
rhodyguy |
Sep 12 2017, 09:22 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Not new beetle switches. T-1. Like the Euro max $12.25 or Empi $10.25 Pelican offers. The $11 door lamp switch gasket seems kind of goofy. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/confused24.gif)
dlkawashima |
Sep 13 2017, 12:38 AM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
911 switch is nothing more than a VW Type 3 dome light. https://www.vwispwest.com/311947111B/Type-3...Dome-Light.html |
arne |
Sep 13 2017, 08:33 AM
Ahhh! I hadn't seen that. About the same price that I paid from Stoddard, with shipping factored in. If this works well, it'll be good to have multiple sources.
Eric_Shea |
Sep 13 2017, 03:15 PM
burton73 |
Sep 13 2017, 05:27 PM
burton73 Group: Members Posts: 3,520 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
E, I think this is what I will put in my HotRod 6
Bob B |
Eric_Shea |
Sep 13 2017, 09:35 PM
Not in #11 (IMG:style_emoticons/default/ohmy.gif)
Arne, the problem you'll have with this light in the back pad is, it grounds to metal on the sides. The back pad is foam all around but, this is why they have the ground wire up there so, I'm sure you can figure something out... |
arne |
Sep 13 2017, 10:16 PM
Yup, it arrived today, and i have already tested and figure out which wires go where to make it work. No problems there. Will attempt to open up the hole in the back pad either tomorrow or Friday.
GeorgeRud |
Sep 14 2017, 07:35 AM
Eric's photo shows the light mounted into the firewall. With appropriate grounding, can it be incorporated into the stock backpad or is the 911 light too deep to Fit?
rhodyguy |
Sep 14 2017, 07:54 AM
The pad hole for the stock light has to be altered.
arne |
Sep 14 2017, 08:28 AM
Yes, the hole in the backpad must be enlarged a bit. But the depth of the light is similar to the stock light, so I don't expect any problem on that score.
GeorgeRud |
Sep 14 2017, 08:40 AM
I found this replacement LED bulb to replace the original bulb. It's much brighter than the factory one, but unfortunately still runs hot. I was hoping that the LED would be cooler than the original to help preserve the original fixture as heat is the main culprit in making them more fragile. If anyone knows of a cooler running USB, please share the info.
arne |
Sep 15 2017, 04:57 PM
The new Type 3/356/911 light is installed, and works perfectly.
The opening in the back pad needs to be enlarged on all 4 sides. I made a cardboard template to get the rough size transferred to the back pad. Overall opening size is 95mm x 38mm with rounded corners similar to the stock opening. If your back pad still has the metal tabs for the light to clip to, both tabs will need to be trimmed by 3-4mm each side. (I used a Dremel with carbide cutoff wheel.) The new light has three terminals to connect, so all three stock wires are used.
In the middle position, the light works with the door switches. Pivot to one side to be on all the time, to the other to be off always. |
RickS |
Sep 15 2017, 08:36 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Looks muy excellent. Nice job.
I bought an aftermarket replacement for mine and had the typical fitment problem. 1 minute with Mr Dremel took care of it, but your solution looks sooo much better. |
rhodyguy |
Sep 17 2017, 07:53 AM
That turned out nice. Good work!
Lo-Fi Version | Time is now: 14th May 2024 - 06:43 AM |
