6 - Oil cooler help?, 911 to 914 |
KeithVonLaws |
Sep 7 2017, 02:43 PM
Member Group: Members Posts: 57 Joined: 19-July 16 From: Napoleon , Ohio 43545 Member No.: 20,205 Region Association: North East States |
Hello Guys
I was wondering if anyone here modifies 911 oil coolers to work on a 914? |
GeorgeRud |
Sep 7 2017, 04:48 PM
Try Patrick Racing in Phoenix, AZ. I believe there are other out there as well as it's just welding a 90 degree angle on a shortened oil cooler pipe. I got mine from Otto's (RIP John) in Venice, CA back in the day
Sep 7 2017, 05:12 PM
as it's just welding a 90 degree angle on a shortened oil cooler pipe If i'm not mistaken, the stock 914/6 cooler has a 90 degree radius bend and not a 90 degree angle. (IMG:style_emoticons/default/idea.gif) |
mb911 |
Sep 7 2017, 05:47 PM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Its not to difficult. I can do the mod if you need.. I need to do mine anyway.
KeithVonLaws |
Sep 7 2017, 07:08 PM
eitnurg |
Sep 8 2017, 01:50 AM
Country Member Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None |
A real one.
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm6.staticflickr.com-62-1504857049.1.jpg) BTW, it's on the supply side, so there's no pressure there: suction, if anything. A quick-and-dirty solution could be to simply saw off the pipe and fit a flexible with a hose clamp. Does the existing pipe offer any support to the cooler? (I'm not recommending: just sayin'). |
Retroracer |
Sep 8 2017, 07:17 AM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Clewett did the modification on mine: http://www.clewett.com
Has options on AN- thread size, metric, etc as I recall. |
Larmo63 |
Sep 8 2017, 08:33 AM
Rich Johnson did the one on my car, he pressure tested it and welded on an AN 16 male outlet.
Perfect. |
914dave |
Sep 8 2017, 02:04 PM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Rich Johnson did mine.
porschetub |
Sep 8 2017, 02:08 PM
mb911 |
Sep 8 2017, 02:10 PM
Becuase its suction side a sharp 90 works just as PMS does. There are so many ways to do this and really not right answer. What I do is 45 it and weld them pretty easy and clean.
Mark Henry |
Sep 8 2017, 03:54 PM
I welded my own (IMG:style_emoticons/default/smile.gif)
I used a $8 fueling hose 1" NPT elbow from a farm supply shop. Cut it on a lathe to slip into the cooler tube then TIG welded it on. Made the hose from a bunch of 911 suction hoses I had kicking around, I have about $30-$40 into my whole return system. |
jim912928 |
Sep 8 2017, 05:59 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Rich Johnson did mine also....excellent work.
KeithVonLaws |
Sep 8 2017, 06:57 PM
Thanks for all of the Tips guys... This is my first 6 so I am excited to start the collection the extra parts..... I have a low mileage 2.2 T engine that I will be bringing up to S specs....
Lo-Fi Version | Time is now: 15th May 2024 - 02:08 PM |
