KeithVonLaws
Sep 7 2017, 02:43 PM
Hello Guys
I was wondering if anyone here modifies
911 oil coolers to work on a 914?
GeorgeRud
Sep 7 2017, 04:48 PM
Try Patrick Racing in Phoenix, AZ. I believe there are other out there as well as it's just welding a 90 degree angle on a shortened oil cooler pipe. I got mine from Otto's (RIP John) in Venice, CA back in the day
Sep 7 2017, 05:12 PM
QUOTE(GeorgeRud @ Sep 7 2017, 03:48 PM)
If i'm not mistaken, the stock 914/6 cooler has a 90 degree radius bend and not a 90 degree angle.
mb911
Sep 7 2017, 05:47 PM
Its not to difficult. I can do the mod if you need.. I need to do mine anyway.
KeithVonLaws
Sep 7 2017, 07:08 PM
QUOTE(mb911 @ Sep 7 2017, 07:47 PM)
Awesome Ben.... Im not in a big hurry but I would be happy to pay you for the work. Call me and I will exchange info and ship to you.
Thanks Keith
4199061817
eitnurg
Sep 8 2017, 01:50 AM
A real one.
BTW, it's on the supply side, so there's no pressure there: suction, if anything. A quick-and-dirty solution
could be to simply saw off the pipe and fit a flexible with a hose clamp. Does the existing pipe offer any support to the cooler? (I'm
not recommending: just sayin').
Retroracer
Sep 8 2017, 07:17 AM
Clewett did the modification on mine:
http://www.clewett.comHas options on AN- thread size, metric, etc as I recall.
Larmo63
Sep 8 2017, 08:33 AM
Rich Johnson did the one on my car, he pressure tested it and welded on an AN 16 male outlet.
Perfect.
914dave
Sep 8 2017, 02:04 PM
Rich Johnson did mine.
porschetub
Sep 8 2017, 02:08 PM
Can be done this way too ;
Click to view attachmentI used a sweep bend on the hose to join them up.
Local alloy boatbuilder did the welding for $40.
Chuck @ Elephant Racing will most likely have a weld on fitting,great go to guy for hoses and fitting too.
mb911
Sep 8 2017, 02:10 PM
Becuase its suction side a sharp 90 works just as PMS does. There are so many ways to do this and really not right answer. What I do is 45 it and weld them pretty easy and clean.
Mark Henry
Sep 8 2017, 03:54 PM
I welded my own
I used a $8 fueling hose 1" NPT elbow from a farm supply shop. Cut it on a lathe to slip into the cooler tube then TIG welded it on.
Made the hose from a bunch of 911 suction hoses I had kicking around, I have about $30-$40 into my whole return system.
jim912928
Sep 8 2017, 05:59 PM
Rich Johnson did mine also....excellent work.
KeithVonLaws
Sep 8 2017, 06:57 PM
Thanks for all of the Tips guys... This is my first 6 so I am excited to start the collection the extra parts..... I have a low mileage 2.2 T engine that I will be bringing up to S specs....
