Oil quantity for ''6'',those without a front cooler, getting various confusing answers ??? |
porschetub |
Sep 8 2017, 05:33 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Stock 914/6 is 7 litres ,have trawled for answers and have had 8.5,9,10 quarts and some running even more but think that's for 911's,I think the 911 tank is larger judging by the 2 I have.
I currently run 7.5 litres because I have larger oil lines and so called larger ''upgrade'' filter,just feel it should be a little more. I can't trust the oil level on the dipstick because it is a PMS one and my tank is stock 914/6,I kinda feel this filler neck/dipstick is for their aftermarket tank (IMG:style_emoticons/default/confused24.gif) . A US quart is more than 1 litre so I'am thinking of running 9 liters total ,don't want to overfill it for obvious reasons but would like to be over to read the dipstick engine running on level ground. TIA (IMG:style_emoticons/default/beer.gif) |
db9146 |
Sep 8 2017, 06:37 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I have stock -6 and it takes 9.5 quarts for mine when I change mine....no remote cooler.
wndsrfr |
Sep 8 2017, 07:45 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
With this much oil volume in the system, it will expand when hot, so be sure to be checking with the engine running and hot. There's no way that we would be starving the system with 8 or more quarts in it, and if you're on the track you don't want to be sloshing it into the vent, so I lean toward having just about 1/2-1 inch on the dipstick, no need for more in my opinion.
Sep 8 2017, 07:49 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Stock 914/6 is 7 litres ,have trawled for answers and have had 8.5,9,10 quarts and some running even more but think that's for 911's,I think the 911 tank is larger judging by the 2 I have. I currently run 7.5 litres because I have larger oil lines and so called larger ''upgrade'' filter,just feel it should be a little more. I can't trust the oil level on the dipstick because it is a PMS one and my tank is stock 914/6,I kinda feel this filler neck/dipstick is for their aftermarket tank (IMG:style_emoticons/default/confused24.gif) . A US quart is more than 1 litre so I'am thinking of running 9 liters total ,don't want to overfill it for obvious reasons but would like to be over to read the dipstick engine running on level ground. TIA (IMG:style_emoticons/default/beer.gif) 1 us liquid quart = 0.946 liter Oil is measured hot with engine running. |
porschetub |
Sep 8 2017, 09:01 PM
With this much oil volume in the system, it will expand when hot, so be sure to be checking with the engine running and hot. There's no way that we would be starving the system with 8 or more quarts in it, and if you're on the track you don't want to be sloshing it into the vent, so I lean toward having just about 1/2-1 inch on the dipstick, no need for more in my opinion. Thanks John,always check it warmed and running,got you on the oil getting down the vent, reason for being a little cautious. Will add more and report back (IMG:style_emoticons/default/beer.gif) . |
Spoke |
Sep 9 2017, 05:41 AM
Jerry Group: Members Posts: 6,984 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
What I do with my 930 when changing oil is to drain all the oil from the crankcase and tank into one bucket. As I add quarts of oil, I fill the empty quart containers with the used oil. I add as many quarts of oil as the old oil fills the empty containers. This gets me close enough to run the engine and top off.
mb911 |
Sep 9 2017, 09:37 AM
914 Guru Group: Members Posts: 6,855 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
:agree
I do the same thing: |
porschetub |
Sep 11 2017, 02:50 PM
Settled on 8.5 litres and have 1'' showing on dipstick,great I now have a reference point,engine is basically leak free now also.
The top mark on the stick isn't going work ,confirms my theory the PMS filler is made for their tank not a stock one,I will make some new marks. Thanks for the helpful replies (IMG:style_emoticons/default/beer.gif) . |
Sep 11 2017, 04:32 PM
1 us liquid quart = 0.946 liter So that means my 16 quarts are just over 15 Liter ... (IMG:style_emoticons/default/wacko.gif) |
Sep 11 2017, 05:30 PM
1 us liquid quart = 0.946 liter So that means my 16 quarts are just over 15 Liter ... (IMG:style_emoticons/default/wacko.gif) I dont know why OP said a quart is more than a liter? |
Sep 11 2017, 06:03 PM
1 us liquid quart = 0.946 liter So that means my 16 quarts are just over 15 Liter ...(IMG:style_emoticons/default/wacko.gif) I just never realized i had 15 liters of oil in my car. I really had no idea how much a quart was. (IMG:style_emoticons/default/unsure.gif) |
Lo-Fi Version | Time is now: 22nd May 2024 - 08:50 AM |
