Show us your splitter! |
HalfMoon |
Sep 9 2017, 09:10 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
I had posted this inquiry before in the garage but I suppose I really should have posted it here...
I've a Sheridan standard wide-body that I'm having some floating issues with (no doubt due to the sbc anchor out back) and so I've decided to build a splitter in the hopes of keeping things a bit more stable. As you can see I have a duck tail but it's useless for any kind of real downforce nor can I say I'm keen on building a wing as this car is also streeted, but I think a splitter may help. Let's see what ya'll are building/have built! Thanks David |
Cracker |
Sep 12 2017, 08:25 PM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
LF 553 RF 534
LR 777 RR 758 This includes my weight with fuel...LS7 all-aluminum engine. 2622 Total 50% cross weight and 42/58 |
HalfMoon |
Sep 12 2017, 08:30 PM
stownsen914 |
Sep 13 2017, 08:53 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Wandering can happen for multiple reasons. I'd be surprised if a splitter is needed to fix your situation, since you don't have a large rear spoiler or a wing. A couple things I'd check before making a splitter:
- As stated by someone else in this thread, I'd add some rear toe-in. 914 rear trailing arms and their mounting points are very flexible. A little extra toe is needed to keep you from going to positive toe at the back. If you are going positive by chance, that could cause wandering. - Have you bump steered the front suspension? Most lowered 914s need to be bump steered. When I first set up my 914 racecar, I took it to the track for a shakedown before I had time to bump steer it. It wandered ALL OVER THE PLACE at speed. Set the bump steer, and voila, problem gone. Scott |
HalfMoon |
Sep 13 2017, 10:05 AM
Wandering can happen for multiple reasons. I'd be surprised if a splitter is needed to fix your situation, since you don't have a large rear spoiler or a wing. A couple things I'd check before making a splitter: - As stated by someone else in this thread, I'd add some rear toe-in. 914 rear trailing arms and their mounting points are very flexible. A little extra toe is needed to keep you from going to positive toe at the back. If you are going positive by chance, that could cause wandering. - Have you bump steered the front suspension? Most lowered 914s need to be bump steered. When I first set up my 914 racecar, I took it to the track for a shakedown before I had time to bump steer it. It wandered ALL OVER THE PLACE at speed. Set the bump steer, and voila, problem gone. Scott I did add a bump steer to it. Thinking the toe in is creating most of the problem but wondering about how much I can adjust given I don't have camber plates and have the front maxed out at this point... Not sure how much more adjustment I can go given that fact :-( Mebbe adding a bit more weight in the front could add a lil more stability? |
Lo-Fi Version | Time is now: 27th May 2024 - 08:53 AM |
