Yet another tire question, 195-55-15 |
Robnxious |
Sep 10 2017, 02:41 PM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
Yes, I know they will fit on a narrow body, that's not my question. My question is, if you have gone to the lower profile tire, how did you like it? How much does this lower the car as well, since I already scrap coming out the driveway, and just now went and bought one of those Bridjit curb ramps. I plan on also adding Mark's fiberglass airdam on it too. So basically my questions are
1) I know you get better handling due to less tire sway, but how is the ride compared to a higher profile tire? I have never driven on low profiles, and think they would look and perform nicely, but haven't heard (or remember reading) about people who have the lower profile tires. I think the 195s are the biggest I can fit in there from what I have seen, and I sort of like the narrow body look. 2) Will they make the car so low that clearance is a major issue? Does no good to lower the go kart down further if I can't get over one of Sacramento's MANY speed bumps Thanks |
JamesM |
Sep 12 2017, 03:33 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Are you running on stock rims? I think anything over 185 width looks silly on stock rims, the tire just balloons out to much. Its less noticeable with shorter sidewalls but then you run into the issue of not filling out the wheel well. Also going with a tire treadwidth larger than the rim width can adversely affect handling. My choice for stick rims is either 185/70 if you can get it but tire selections sucks in that size or 185/65 isnt horrible and slightly more common.
If you want to run a wider tire get a wider rim. There are 15x7 and 16x7 4 bolt rims available that will let you run a 205 width without looking ridiculous. |
Lo-Fi Version | Time is now: 19th May 2024 - 01:56 PM |
