Yet another tire question, 195-55-15 |
Robnxious |
Sep 10 2017, 02:41 PM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
Yes, I know they will fit on a narrow body, that's not my question. My question is, if you have gone to the lower profile tire, how did you like it? How much does this lower the car as well, since I already scrap coming out the driveway, and just now went and bought one of those Bridjit curb ramps. I plan on also adding Mark's fiberglass airdam on it too. So basically my questions are
1) I know you get better handling due to less tire sway, but how is the ride compared to a higher profile tire? I have never driven on low profiles, and think they would look and perform nicely, but haven't heard (or remember reading) about people who have the lower profile tires. I think the 195s are the biggest I can fit in there from what I have seen, and I sort of like the narrow body look. 2) Will they make the car so low that clearance is a major issue? Does no good to lower the go kart down further if I can't get over one of Sacramento's MANY speed bumps Thanks |
arne |
Sep 10 2017, 02:52 PM
Serial Rescuer of old vehicles... Group: Members Posts: 737 Joined: 31-January 17 From: Eugene, Oregon Member No.: 20,799 Region Association: None |
Overall diameter of a 195/55 is about 23.4", compared to stock sizes at 25.0". This means you will lower your effective ride height by about half of the difference, so call it 3/4" or so lower if you now have a stockish size on the car. It will be significant if you already have clearance issues.
Ride will generally be harsher, but how much harsher will be dependent on the particular tire make and model you select. |
Robnxious |
Sep 10 2017, 03:29 PM
Overall diameter of a 195/55 is about 23.4", compared to stock sizes at 25.0". This means you will lower your effective ride height by about half of the, so call it 3/4" or so lower if you now have a stockish size on the car. It will be significant if you already have clearance issues. Ride will generally be harsher, but how much harsher will be dependent on the particular tire make and model you select. Thanks, I plan on using a good performance tire, probably about a 300 or 400 in what ever that scale is called for stickiness. I've only had issues with clearance getting out of my driveway, and am hoping that this Bridjit ramp will take care or that, though I won't be putting the tires on until I see how much more clearance I have with that. |
Lo-Fi Version | Time is now: 7th May 2024 - 03:06 AM |
