Yet another tire question, 195-55-15 |
Robnxious |
Sep 10 2017, 02:41 PM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
Yes, I know they will fit on a narrow body, that's not my question. My question is, if you have gone to the lower profile tire, how did you like it? How much does this lower the car as well, since I already scrap coming out the driveway, and just now went and bought one of those Bridjit curb ramps. I plan on also adding Mark's fiberglass airdam on it too. So basically my questions are
1) I know you get better handling due to less tire sway, but how is the ride compared to a higher profile tire? I have never driven on low profiles, and think they would look and perform nicely, but haven't heard (or remember reading) about people who have the lower profile tires. I think the 195s are the biggest I can fit in there from what I have seen, and I sort of like the narrow body look. 2) Will they make the car so low that clearance is a major issue? Does no good to lower the go kart down further if I can't get over one of Sacramento's MANY speed bumps Thanks |
HansJan |
Sep 12 2017, 08:39 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
205/40/16 is the size on my tires.
The overall diameter is about 22 1/2". The result is that I'm running somewhere around 3,200 rpm just cruising on the highway. That's not right. And (of course) my speedo is way-off. Can't wait to wear them out, so I can justify getting taller tires. |
DRPHIL914 |
Sep 12 2017, 08:54 PM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
205/40/16 is the size on my tires. The overall diameter is about 22 1/2". The result is that I'm running somewhere around 3,200 rpm just cruising on the highway. That's not right. And (of course) my speedo is way-off. Can't wait to wear them out, so I can justify getting taller tires. that is really small! i was set up like that dor a while with some empi 15" rims rubbed a bit even with 185 tires due to the vw offset- my 205 55/16 on a 16x6" rim will not rub, in fact i have plenty of space, the 7" did rub in rear btw, but once these tires wear out i will go down to proper diameter with 205/50-16 - try the potenza - |
Lo-Fi Version | Time is now: 7th May 2024 - 02:27 AM |
