Yet another tire question, 195-55-15 |
Robnxious |
Sep 10 2017, 02:41 PM
RobnxiousOne Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
Yes, I know they will fit on a narrow body, that's not my question. My question is, if you have gone to the lower profile tire, how did you like it? How much does this lower the car as well, since I already scrap coming out the driveway, and just now went and bought one of those Bridjit curb ramps. I plan on also adding Mark's fiberglass airdam on it too. So basically my questions are
1) I know you get better handling due to less tire sway, but how is the ride compared to a higher profile tire? I have never driven on low profiles, and think they would look and perform nicely, but haven't heard (or remember reading) about people who have the lower profile tires. I think the 195s are the biggest I can fit in there from what I have seen, and I sort of like the narrow body look. 2) Will they make the car so low that clearance is a major issue? Does no good to lower the go kart down further if I can't get over one of Sacramento's MANY speed bumps Thanks |
ThreeV8s |
Sep 13 2017, 09:38 AM
Member Group: Members Posts: 116 Joined: 11-March 17 From: West Chester, PA Member No.: 20,915 Region Association: North East States |
Slightly off-topic, but is everyone replacing their spare as well when going to a different size? For example, if your spare is 165/80 15 with a 25.4" diameter (and in excellent shape), would you swap it out if you went to 195/65 with a 25.0" diameter? Would there be any impact on the car if used to get you home?
mepstein |
Sep 13 2017, 10:30 AM
914-6 GT in waiting Group: Members Posts: 19,256 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Slightly off-topic, but is everyone replacing their spare as well when going to a different size? For example, if your spare is 165/80 15 with a 25.4" diameter (and in excellent shape), would you swap it out if you went to 195/65 with a 25.0" diameter? Would there be any impact on the car if used to get you home? It wont make any difference on the front. I dont know if it makes a difference on the rear but you could always move a good one to the rear if it does. I would use whatever size you have unless you also rotate the spare with your other wheels on a regular basis. |
ThreeV8s |
Sep 13 2017, 11:16 AM
It wont make any difference on the front. I dont know if it makes a difference on the rear but you could always move a good one to the rear if it does. I would use whatever size you have unless you also rotate the spare with your other wheels on a regular basis. Thanks Mark! That's what i figured. I'd imagine two tires of the same size and model could probably have a similar discrepancy if one is new and one well-worn. |
Lo-Fi Version | Time is now: 7th May 2024 - 09:55 AM |
