spark plug seals, in or out... |
yeahmag |
Sep 10 2017, 04:30 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Is the general consensus still to push the rubber seal for the spark plugs INSIDE the cylinder tin (so it seals) under pressure?
-Aaron |
injunmort |
Sep 10 2017, 04:51 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
mine have a groove that slips into the tins, positive seal at all times
Porschef |
Sep 10 2017, 05:39 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
What are those, Mort? That makes the most sense...
Elliot Cannon |
Sep 10 2017, 05:53 PM
SO.O.C914er |
Sep 10 2017, 08:37 PM
Senior Member Group: Members Posts: 1,250 Joined: 18-July 16 From: Mission Viejo Ca Member No.: 20,199 Region Association: Southern California |
Do you see any difference when there pushed inside. Mine are just resting on the outside not tight at all (IMG:style_emoticons/default/idea.gif)
MartyYeoman |
Sep 10 2017, 10:04 PM
Senior Member Group: Members Posts: 1,519 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
michael7810 |
Sep 11 2017, 06:45 AM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Elliot Cannon |
Sep 11 2017, 07:29 AM
mine have a groove that slips into the tins, positive seal at all times I've been looking for just that type of seal system. Where did you get yours? Looks like a new product idea for 914rubber?? I use the regular seals and just push them through the holes with a screw driver. |
NFBrown |
Sep 11 2017, 08:00 PM
Newbie Group: Members Posts: 34 Joined: 27-February 13 From: Boise, Idaho Member No.: 15,587 Region Association: Pacific Northwest |
Corvair engines had a plug seal that snapped into the tin. I wonder if they could be adapted.
Nick |
Mikey914 |
Sep 13 2017, 10:49 AM
The rubber man Group: Members Posts: 12,671 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Let me check I may have one that would work nicely.
MartyYeoman |
Sep 13 2017, 12:35 PM
Something like this. I'm not sure of the hole size of the in Corvair's tin and if it will work for the 914 tins.
Attached thumbnail(s) |
NFBrown |
Sep 13 2017, 05:01 PM
Looks like it's worth a try. I think I'll order some.
Nick |
Mikey914 |
Sep 13 2017, 06:29 PM
Checked my grommets, and the one that would work nicely was a little too small. (IMG:style_emoticons/default/headbang.gif)
injunmort |
Sep 14 2017, 10:13 AM
beru set from partsgeek, about $24.00
Mikey914 |
Sep 14 2017, 01:47 PM
Beru is exactly the same, it's an in or out also. I have a set in my hands.
euro911 |
Sep 14 2017, 01:55 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
If you push the seals down on the barrel of the connector prior to pushing them onto the plugs, they seal just fine (as designed by the factory) (IMG:style_emoticons/default/shades.gif)
Mikey914 |
Sep 14 2017, 01:58 PM
Yes, it looks like they will hold some tension. But not a "grommet" type of fit if that's whats wanted.
Mark |
MartyYeoman |
Sep 15 2017, 01:03 PM
You're correct, Mark. Grommet fit is the goal.
Rand |
Sep 15 2017, 01:43 PM
There isn't that much pressure under there!! The idea that pressure will push the rubber against the underside of the tin hard enough to seal is a misnomer. A pretty ridiculous one.
Use all the gauges you want, try it both ways. You won't notice a difference in head or oil temps. Sometimes we get way out of reality with ignoramus details. |
era vulgaris |
Sep 15 2017, 04:07 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
There isn't that much pressure under there!! The idea that pressure will push the rubber against the underside of the tin hard enough to seal is a misnomer. A pretty ridiculous one. Use all the gauges you want, try it both ways. You won't notice a difference in head or oil temps. Sometimes we get way out of reality with ignoramus details. (IMG:style_emoticons/default/agree.gif) Just push them until they seat firmly from the outside. That's all you need to do. |
Lo-Fi Version | Time is now: 22nd May 2024 - 03:15 AM |
