Spal Fans, which direction |
flmont |
Sep 10 2017, 07:10 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
old dog |
Sep 10 2017, 07:47 PM
Member Group: Members Posts: 63 Joined: 14-December 12 From: Oxnard,CA. Member No.: 15,257 Region Association: Central California |
gereed75 |
Sep 10 2017, 07:52 PM
Senior Member Group: Members Posts: 1,246 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
In general, you want it to pull. Just did one and from memory the wires are color coded for + red and - black.
Also, I am not a motor expert, but I believe these brushed DC motors will spin either way, depending on the applied polarity. Motor experts are welcome to set us straight on that one. |
McMark |
Sep 11 2017, 05:41 AM
They will spin either way, but SPAL specifies a direction, and I respect their brand enough to trust them. So I say find out which way it goes by the part number, and if it's not what you need get a different one.
IronHillRestorations |
Sep 11 2017, 06:06 AM
They make pushers and pullers, so you need the correct one. I'll opine that the fan blades are made to work best when used in the correct orientation.
gereed75 |
Yea you are right Mark. The motor may operate in either direction but the blades are optimized for their designed direction of rotation. The fans come in either push or pull versions for the same motor.
Oops, beat meet to it Perry |
flmont |
Sep 11 2017, 02:58 PM
Do U think the picture of the fan I have is a puller type fan..?? Thanks..Frank
76-914 |
Sep 11 2017, 03:01 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,501 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Puller. Note the blades distance from one side as opposed to the other?
flmont |
Sep 11 2017, 03:17 PM
ah cool,..I have 2 more just like it..!!
jd74914 |
Sep 11 2017, 04:14 PM
Puller. Note the blades distance from one side as opposed to the other? Not so fast there...check the part number. I'm 99% sure SPAL fans don't always spin CW and some of their pullers use the same blade design and clocking orientation as pushers and vice versa. They have identical looking fans with different part numbers for pushing and pulling with slightly different prices too so there may be subtle motor or wiring differences. |
flmont |
Sep 11 2017, 04:21 PM
I have been trying to get with there tech dept not much luck tho...
jd74914 |
Sep 11 2017, 04:40 PM
Do you have the number?
bdstone914 |
Sep 11 2017, 10:15 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
bdstone914 |
Sep 11 2017, 10:18 PM
bdstone914 |
Sep 11 2017, 10:27 PM
In general, you want it to pull. Just did one and from memory the wires are color coded for + red and - black. Also, I am not a motor expert, but I believe these brushed DC motors will spin either way, depending on the applied polarity. Motor experts are welcome to set us straight on that one. Generally true but some motors are reversible and fan makers do not like to have double the fan SKU's by having the wire colors consistent to + pos and - neg. Use one motor in both applications with either a puller or pusher blade. Some motors are not reversible due to brush angle optimised to reduce drag in one direction. When reversed the wear the brushes fast. Most of the modern motors are brushless. Like other have said get the part number off of the sticker on the fan if you can read it. Or match it to size and config on there site. Hook it up and see how much air it pulls. What is the whole deal here? Airflow in and out and cooling what engine ? Fans mainly assist in low speed. The motion of the vehicle should move enough air to cool the engine. |
flmont |
Sep 12 2017, 05:16 PM
bdstone914,..fans are for cooling a 92' 3.3 suby six,.I did find out today they are puller fans,altho discontinued but iam hoping they work !!
flmont |
Sep 12 2017, 05:47 PM
Thanks..!!
Lo-Fi Version | Time is now: 15th May 2024 - 12:55 PM |
