Distributor question-, whats the difference between these 2? |
DRPHIL914 |
Sep 11 2017, 07:16 PM
Dr. Phil Group: Members Posts: 5,767 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i looked up on anders somight to see what the numbers mean,
and one is listed for a 2.0 , 74-76 the other one(cleaner one) says 75-75. i can tell you the both ran like crap compared to whats in the car and i really thought when i bought the nice lean one with all new stuff inside it would run much better- one onther thing is they are off from each other 180' so no wonder one ran bad but the it doesnt explain the clean one on right- are they both for a d-jet or one for L- jer and does it matter? Attached thumbnail(s) |
914sgofast2 |
Sep 11 2017, 07:26 PM
Senior Member Group: Members Posts: 617 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
i looked up on anders somight to see what the numbers mean, and one is listed for a 2.0 , 74-76 the other one(cleaner one) says 75-75. i can tell you the both ran like crap compared to whats in the car and i really thought when i bought the nice lean one with all new stuff inside it would run much better- one onther thing is they are off from each other 180' so no wonder one ran bad but the it doesnt explain the clean one on right- are they both for a d-jet or one for L- jer and does it matter? Probably have different advance/retard curves, with the one for the 1975 being more retarded so the cars woudl pass the stricter emission requirements in 1975. |
porschetub |
Sep 11 2017, 09:44 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
i looked up on anders somight to see what the numbers mean, and one is listed for a 2.0 , 74-76 the other one(cleaner one) says 75-75. i can tell you the both ran like crap compared to whats in the car and i really thought when i bought the nice lean one with all new stuff inside it would run much better- one onther thing is they are off from each other 180' so no wonder one ran bad but the it doesnt explain the clean one on right- are they both for a d-jet or one for L- jer and does it matter? Probably have different advance/retard curves, with the one for the 1975 being more retarded so the cars woudl pass the stricter emission requirements in 1975. I seem to remember the end letter (VW) A,B or what refers to the type of vacuum unit,have you checked the movement of the advance plates must be free and easy. These units have a bad rep for sticking up on the advance plate a very common issue ,seen lots when I rebuilt them years ago. |
Sep 11 2017, 10:47 PM
I think I can see one of the mounting screws for the trigger points on the left side of the dirty one. I'm pretty sure I can see the end of the trigger points cover on the clean one.
That would say they are both D-jet distributors. --DD |
BillC |
Sep 12 2017, 06:00 AM
Senior Member Group: Members Posts: 540 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
I think I can see one of the mounting screws for the trigger points on the left side of the dirty one. I'm pretty sure I can see the end of the trigger points cover on the clean one. That would say they are both D-jet distributors. --DD I'm guessing they would both have to be D-jet distributors, or the car wouldn't run at all. Might want to check the vacuum canisters to see if they hold vacuum. Then, check the advance movement, as mentioned above. |
914_teener |
Sep 12 2017, 08:35 AM
914 Guru Group: Members Posts: 5,199 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I think I can see one of the mounting screws for the trigger points on the left side of the dirty one. I'm pretty sure I can see the end of the trigger points cover on the clean one. That would say they are both D-jet distributors. --DD I'm guessing they would both have to be D-jet distributors, or the car wouldn't run at all. Might want to check the vacuum canisters to see if they hold vacuum. Then, check the advance movement, as mentioned above. (IMG:style_emoticons/default/agree.gif) x10 |
Lo-Fi Version | Time is now: 22nd May 2024 - 06:08 AM |
