Paint over Rust reformer needed? |
Calwaterbear |
Sep 13 2017, 11:54 AM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
so I've hit the floor pan, inside and outside with the rustolium rust reformer.
so do I paint another coat over that? and iff so? what? just an enamel? |
burton73 |
Sep 13 2017, 02:43 PM
burton73 Group: Members Posts: 3,516 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
From Rust-Oleum__ Not sure if the stuff works or not? ABOUT RUST REFORMER Stop rust in its tracks with Rust-Oleum® Automotive Rust Reformer. Without sanding, the coating bonds with rusty metal transforming it into a flat-black, non-rusting surface. Instantly convert rust into a protected, paintable surface Prevent future rust and corrosion Odorless, water soluble and safe to apply Compatible with oil-based, lacquers or aerosol top coat paints FOR BEST RESULTS Apply several light coats a few minutes apart to prevent running and sagging. AVAILABLE SIZES |
Rand |
Sep 13 2017, 02:54 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
I use Ospho. Great rust converter. But I would NEVER use that as a finish. Definitely paint over it to give you a better chance of keeping it from coming back. Seal it! (IMG:style_emoticons/default/smile.gif) Rust needs oxygen. Better to suffocate it than risk feeding it.
Lo-Fi Version | Time is now: 12th May 2024 - 01:49 PM |
