brake light is flashing, how to make it stop? |
TROJANMAN |
May 20 2005, 08:37 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
Had a new MC (19mm) and new brake lines (OEM rubber) installed yesterday. i also used the blue brake fluid. brakes work MUCH better now. but, the brake light won't stop flashing. what's causing this?
thanks in advance |
scotty914 |
May 20 2005, 08:46 AM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
reset the switch on the mc, it is under a little rubber boot
john rogers |
May 20 2005, 08:47 AM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
If the switch on the m/c has a small button, just press it and it will reset it. It can also be the switch at the parking brake lever too. On both our cars (73 and 74) there was no button and the switch was good so I finally disconnected the circuit.
Joe Bob |
May 20 2005, 08:54 AM
That's the self destruct warning light..... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif)
TROJANMAN |
May 20 2005, 08:57 AM
thanks. i figured it was the swtich, so i kep the old one in case it was bad. i'll try and get under there tonight.
Gint |
May 20 2005, 10:13 AM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
The weitch probably isn't bad, it just needs to be reset. If you ran the cylinder out of fluid it would do the same thing. They do that out of the box because they never had fluid until installed. Just get under there and push the button. |
Gint |
May 20 2005, 10:19 AM
Search results for master AND reset AND switch
The oldest two threads in there have pics. The oldest has a pic of the button after it's been pushed in. The second oldest thread has a pic of the rubber boot that covers the switch. |
TROJANMAN |
May 20 2005, 10:21 AM
thanks. that will make things much easier
Lo-Fi Version | Time is now: 18th May 2024 - 10:42 AM |
