Going Megasquirt, Crank sensor installation |
Beebo Kanelle |
Sep 14 2017, 11:14 AM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Has anybody installed a crank sensor without dropping the engine?
Any and all guidance and leadership is greatly appreciated. |
jd74914 |
Sep 14 2017, 11:20 AM
Its alive Group: Members Posts: 4,780 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States |
I haven't done it (I installed on a bench), but the one from The Dub Shop just required you to pull the fan shroud which can be done in-car IIRC, so you should be able to install without a drop.
VaccaRabite |
Sep 14 2017, 11:23 AM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You can do it. It ins't fun, especially if you don't have a lift.
You have to: *remove all the front engine tin *prop up the engine with a jack *drop the front of the engine down a few inches. It will be pivoting on the trans-mounts, so you don't want to lower it too far. *pull the dog house. Pull the fan. *install the trigger and hall sensor. Install is reverse of disassembly. Zach |
Beebo Kanelle |
Sep 14 2017, 07:16 PM
Thanks to all.
Porschef |
Sep 15 2017, 03:32 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Unless there's some overwhelming reason why you shouldn't, (doubtful) drop the engine. It's a bit daunting the first time, but that will allow so many other "while I'm in theres" to occur, it will be well worth it.
It's really not difficult. Just requires being methodical and careful. Good luck. |
Lo-Fi Version | Time is now: 16th May 2024 - 12:38 PM |
