1974 2.0L in Phoenix Red for sale |
william1764 |
Sep 14 2017, 02:58 PM
Member Group: Members Posts: 252 Joined: 11-May 10 From: maryland Member No.: 11,717 Region Association: MidAtlantic Region |
1974 Porsche 2.0L, Phoenix Red
Its time she goes. Considered a 6 conversion (my next purchase) however she's too nice the way she is. Absolutely spectacular condition with original paint/interior (paint verified) and approx: 45,000 miles Original #1: Doug Slayback 1974-2002 Owner #2: Jim Chambers 2002-2005 Broker #3: Camp914 2005-2007 Owner #4 Tim Hench 2007-2010 Owner #5 Me 2010 – current Details (most work/upgrades performed during my ownership): • Stainless steel brake lines • Fuel tank removed/cleaned • New/relocated fuel pump • Dual Weber 40IDF carbs (recently rebuilt) w/ matched cam • New Bosch 050 distributor, plugs/wires • New starter motor • New accelerator and clutch cables • Koni adjustable shocks • Bursch exhaust • New poly bronze bushings frt/rr • Brakes/rotors less than 5K miles use • Recent service including valve adjustment • Recent alignment • Weltmeister short shift kit • Authentic COCO floor mats Non matching #'s. Car started out life as 1.8 L. Was replaced with 2.0 L in 2002. This is my 3rd 914. My first in 1982, the year I graduated HS. This is the nicest example I've seen in person. Car is located in Maryland, between Balt and DC. $25k [attachmentid=620 080][attachmentid =620076] Attached thumbnail(s) Attached image(s) |
MikeInMunich |
Sep 16 2017, 12:23 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Question!
In the last photo of the trunk, what is that little tube sticking out of the engine compartment between the jack and the top,of the strut tower? (IMG:style_emoticons/default/confused24.gif) |
william1764 |
Sep 18 2017, 01:27 PM
Question! In the last photo of the trunk, what is that little tube sticking out of the engine compartment between the jack and the top,of the strut tower? (IMG:style_emoticons/default/confused24.gif) Not sure what "tube" you're talking about. It does have battery shut off switch. Is that what you're referring to? It is an L shaped metal handle/switch. Actually quite handy as I generally shut in off position in between use so not to drain on battery. |
Lo-Fi Version | Time is now: 9th May 2024 - 01:33 AM |
