Help needed...wiring fuel pump on V8 conversion |
DickSteinkamp |
Sep 14 2017, 04:52 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
I have a '76 that I'm converting to a V8 with Renegade parts.
I've installed a lower pressure fuel pump in the stock location (between front bulkhead and the fuel tank). I can make the fuel pump run if I ground the upper right terminal in the 4 pin connector in the upper left of this photo. It is the connector the L-Jet plugs into in the relay panel. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.staticflickr.com-20876-1505429537.1.jpg) Is there a better way to insure the fuel pump comes on any time the ignition is on? Thanks |
porschetub |
Sep 14 2017, 05:28 PM
Go to 914info >tech section...all explained there cheers
DickSteinkamp |
Sep 14 2017, 05:42 PM
Lo-Fi Version | Time is now: 5th May 2024 - 08:19 AM |
