I have a '76 that I'm converting to a V8 with Renegade parts.
I've installed a lower pressure fuel pump in the stock location (between front bulkhead and the fuel tank).
I can make the fuel pump run if I ground the upper right terminal in the 4 pin connector in the upper left of this photo. It is the connector the L-Jet plugs into in the relay panel.
Is there a better way to insure the fuel pump comes on any time the ignition is on?
Thanks
