Repairs possible? |
Repairs possible? |
Freezin 914 |
Sep 17 2017, 11:37 AM
Senior Member Group: Members Posts: 850 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
Hi all, can intake manifolds and air cleaner assemblies be repaired if cracked? I have a manifold tab that broke where it mounts. And have an air cleaner assembly that the linkage mount broke, can these parts be welded? (Parts are cast) I was looking to list these carbs for sale and want to know if it is worth trying to have them repaired or just sell the carbs separately. Any info would help. Thank you. (IMG:style_emoticons/default/confused24.gif)
Freezin 914 |
Sep 17 2017, 11:38 AM
Manifold
Attached thumbnail(s) |
nditiz1 |
Sep 17 2017, 11:40 AM
Senior Member Group: Members Posts: 1,180 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
You could repair both via welding and redrull the hole for the manifold, but you are better off just getting a used manifold and some new linkage
green914 |
Sep 17 2017, 11:41 AM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
I think you should replace with new parts.
Freezin 914 |
Sep 17 2017, 11:48 AM
Thank you for the quick replies, I think it will be best to just list them without the manifolds and air cleaners, thanks again.
mb911 |
Sep 17 2017, 02:27 PM
914 Guru Group: Members Posts: 6,820 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I specialize in repiaring aluminum and magnesium castings. I would think these appear repairable fairly easy..
Freezin 914 |
Sep 17 2017, 02:46 PM
mb911 |
Sep 17 2017, 02:53 PM
Wow didn't even realize whom I was replying to.. Yes definitely will .. I
rhodyguy |
Sep 17 2017, 02:57 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,071 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Just sell the carbs by themselves or with the velocity stacks if you have any. Broken castings just add to the shipping cost.
DM_2000 |
Sep 17 2017, 05:42 PM
Member Group: Members Posts: 217 Joined: 16-August 17 From: PA Member No.: 21,351 Region Association: None |
The manifold is repairable without much effort. The linkage mount is repairable but would probably be less $ to replace.
Always let the buyer decide if they want the broken parts shipped. It is far easier to repair a cracked part then it is to make you own from a sand casting. |
IronHillRestorations |
Sep 17 2017, 05:59 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I'd JB weld the piece back on the air cleaner base, after cutting off the cross bar mount, and then use a CSP center pull.
Take the intake to a welder who can do aluminum. |
Freezin 914 |
Sep 17 2017, 09:22 PM
Thank you for all the replies, I listed the carbs, I will hang on to the manifolds and air cleaner bases for now. Thank you all. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 3rd May 2024 - 11:36 PM |
